smallfish
Light Used On L-box
New to L-Box and view a house with nice L-box with multiple lights in small rectangle cover.
Just wondering what type of energy saving light that they are using and whether is it bright enough for reading and most important, is the light too warm?
Contractor say it is very bright and not warm. Just need some opinion before installed the lights
If you are buying a lot of down lights, consider going to those electrical hardware store (but limited design). Only a few of these shops are around. But the cost is about 50% cheaper or more as compared to any lighting shops. Plus you get the ultra bright Philips bulb instead of those cheapo bulbs. Try to get those that uses Compact Fluorescent Light Bulbs (screw on type, no need additional ballast, save electricity) instead of the usual Fluorescent Light Bulbs (four pin socket, needs ballast, which generate a lot of heat)
ya no matter what your house theme is, tell your contractor/id that you want lots of ENERGYSAVING bulbs.
Buy only philips or osram - the rest are crap.
If you have lots of downlight in a row, 5w bulb is suffice.
And you wont regret when you receive your PUB bills.
Thks for the response. Appreciated.
Will look out for the common one used in reno.
