hi Summerholiday,
Thanks for your quick reply. I think I have a typo error at line 38, it's $1980, which is $247.50. Even more descrepancy.
why your no 41 cost $230 per foot run, why yor no 38 cost more its $237.5, pls check, cos you pay $60 more on no38
i suggest you all wan try a&d price? you might see some diff..
Hi Rainbow04
Mine is also new 4 room flat - 90sqm. Let me share my quote for people to comment as well.
Masonry works
1. Supply & lay 600mm x 600mm homogenous tiles **** and dining room - $2,350
2. Supply & lay skirting (homogenous tiles) **** and dining - FOC
For your tiles how much is it cost p.s.f?
Wat are the range of tiles u can get to choose?
3. Supply & lay liminating floor at 3 bedroom and all skirting at 3 bedroom - $1,700
4. Supply & lay homo or ceramic at storeroom area - $350
What brand and grade of laminated flooring you are getting?
5. Alteration of main gate - $70
6. Alteration of main door - $30
Kitchen area
7. Construct cement motar base for kitchen cabinet c/w side tiling $250
8. Construct fridge, washing machine base with tiles - $250
For the washer and fridge base a bit high. Also tell them the measurement of the dimension of the model you are getting of fridge and washer first. Dont let them do it first as you will have no choice but to get the exact or smaller dimension of it.
9. To supply & install piping for kitchen & washing machine $120
Stainless steel or copper?
10. To supply & lay floor tiles at kitchen using tiles - $950
Dont get what this means. But what tiles are you getting? matt homo tiles or ceremet tiles?
11. To apply waterproofing at kitchen floor K11 - $180
Both toilet
12. To supply & overlay floor tiles at both toilets - $750
Are you current tiles in good condition? Are there hollow sound while you use marble and roll on it? you can try it. If there is then would be better dont overlay. Play save. :)
13. To apply waterproofing at both toilets floor K11 - $150
14. Supply & install tempered flass shower screen at both toilet - $900
15. Supply & install vanity top using granite top at master toilet only - $540
16. Supply & install lower cabinet, mirror wall to wall and display glass shelving - $650
Plumbing work
17. Supply & install new s.steel piping for whole house (one way) - $650
Please ensure that they will remove the stainless steel pipings within the wall and change it. Since they did mention the whole house. One way is only for cold water to flow.
18. Supply labour to install two set of instant heater - $120
19. Supply labour to install toilets accessories - both toilets and kitchen - $80
How many sets of accessories that you can install?
20. To supply & install piping for kitchen & washing machine - $120
hmmm sound like a bit extra charge to me. Above already stated supply and install stainless steel piping for the whole house. And why there is extra installation here?
Ceiling works
21. To supply & install L box light holder / false ceiling **** / dining and passage way - $1450
22. To supply & install L box light holder / false ceiling at master bedroom - $680
23. To supply & install simple cornies ceiling at 2 bedroom - $400
Painting works
24. Painting of whole house using ICI / Nippon emulsion paint (no color limit) - $1,100
25. Painting all door / frame / gate / piping etc - $150
Door
26. Supply & install 3 set of bedroom door - solid veneer door with s. steel - $750
Other works
27. Supply & install alum window follow the existing color for whole house - $800
28. Houlage fee & general cleaning and 2 time acid washing for whole house flooring - $350
Please ensure the houlage will be clear and also check with the person when they will do the first acid wash and the second one. 8|
Carpentry work
29. Supply & install kitchen cabinet using solid pry door with 1mm ABS trimming height pressure laminate
Est no. of foot run 12ft top 9 ft bottomr (add cost per foot run $80) - $1,680
What is the brand of laminated you can use for your kitchen cabinet. And also whats the internal laminated too?
30. Supply & install surface granite top at kitchen work top 9 ft. (add cost per foot run $90) - $810
What brand they will give?
31. Stainless steel disk rack 1 set come with s. steel shelving bar display - $900
Sound on the high side. Add cost to the kitech cabinet. By right it is include in it. Unless their design is different.
32. Supply & install full height tempered glass divider - $900
33. Supply & install long bench with back rest, with full height mirror to ceiling 7ft - $980
34. Supply & custom made glass dining table 1200mm x 750mm with wooden leg & granite top - $1,600
Living & dining
35. Supply & install feature wall with display cabinet, mirror, feature wall design, 14 ft - $3,800
36. Supply & install feature wall with mirror (shoe cabinet full height with door) 8 ft - $1,700
Master bedroom
37. Supply & install partition feature wall c/w side table bedhead design 10ft - $2,600
38. Supply & install sliding wardrobe c/w design 8 ft - $1,900
39. Supply & install platform bedbase for king size bed - $850
For all the above please check the brand of laminated and the quality you are getting.
Bedroom 2
40. Supply & install study table top and bottom 14 ft - $1,540
41. Supply & install sliding wardrobe c/w design 6 ft - $1,380
Total - $37,410
Hope it help to clear your doubt. :good:
I just collected my keys to my 5 room flat, 122sqm. Will be renovating mainly on kitchen & 2 toilets, minor on foyer & living room.
Here is the quotation given from 1 of the renovation coy for toilet & kitchen.
Hack off existing flooring at both toilet
Lay antic slip floor tiles at both toilet (20cm x 20cm)
Lay water proofing membrane at both toliet
Hack off existing wall tiles at both toilet
Lay glazed ceramic wall tiles at both toilet (up to ceiling height & 20cm x 25xm with Listello)
2 colours push-top toilet bowl
2 colors basin
2 level tap
2 aluminium bi fold door
Run copper piping
In/outlet for basin
Reinstall wiring with new casing
Haulage & debris removal
Chemical washing
$5580
Hack off existing flooring at both kitchen
Lay country design floor tiles at both Kitchen (30cm x 30cm)
Lay water proofing membrane at kitchen
Hack off existing wall tiles at kitchen
Lay glazed ceramic wall tiles at kitchen (up to ceiling height & 2 tones colors)
2" thick fridge base
2" thick washing machine base
2" thick cabinet base
Run copper piping
In/outlet for washing machine & sink
Chemical washing
10 ft solid plywood kitchen cabinet
$5380
They are individual packages. Any comments?
2 colors basin
2 level tap
Run copper piping
In/outlet for basin
Chemical washing
$5580
Run copper piping
Chemical washing
$5380
This is really too cheap to believe. On average, each toilets cost $3K and above. With your work scope to toilet, costing should be around $6300. Your kitchen should easily cost you $6600 also. Even you are using postform top for your kitchen cabinet, the cost of your cabinet is about $2,100. The cost of Wall tiles (without measurement) easily about $2K floor tiles $1K, cabinet, fridge, w/m base $300, Copper piping $500, Wiring $200, Haulage + debris + Chemical cleaning $500.
There are a few things to take note on the quotes (prevent any hidden costs)
1) Read every single things on what they wrote. Make sure there arent any things being double charges.
2) Check that all the things that are stated during conversation or anything added should be written on it and counter sign from the ID. or print out a new copy.
3) Check on their terms and conditions. (maybe a lot of words but please read it all.)
hope it helps
on avg, how much do companies charge haulage fees? I was quoted between $300 - $1100! what big difference!
One company do not charge at all as they told me that my house do not require hacking, so no haulage fees. what is haulage fees btw? is it that big container parked at the car park, for contractors to collect debris?
plastering of walls, what is considered reasonable pricing? some charge me one lump sum $300 for plastering all affected parts. some say must go down to site and see.
Edited by jt88
Hi my friends,
I have since been shopping around for more quotes since my last post. Went to 5-6 more IDs and found this one ID whom we are most comfortable with.
Any comments on his quotes? Thanks. :P:P:P
DESCRIPTION QTY AMOUNT
1 DEMOLITION
A To hack existing floor and wall tiles :- Lump sum $2,500.00
Kitchen
2 Bathroom
Service Balcony
B To dismantle existing cabinet :- Lump sum Inclusive
Kitchen
C To dismantle existing recess cabinet :- Lump sum Inclusive
3 Bedroom
Study
D To dismantle existing wardrobe :- Lump sum Inclusive
Master Bedroom
E To dismantle existing cornice :- Lump sum Inclusive
Living / Dining
3 Bedroom
Study
F To dismantle existing doors :- Lump sum Inclusive
3 Bedroom
Store
2 WET WORK
A To supply and lay water proofing :- Lump sum $300.00
Kitchen
2 Bathroom
Service Balcony
B To cement screed hacked wall :- Lump sum $1,200.00
Kitchen
C To construct cabinet , fridge and washing machine base :- Lump sum $400.00
Kitchen
D To construct shower kerb :- Lump sum $160.00
2 Bathroom
E To construct kerb :- Lump sum $80.00
Main Entrance
F To construct hollow block wall :- Lump sum $400.00
Between Kitchen & Living
3 FLOOR
A To supply and lay matt homogeneous / ceramic tiles :-
Kitchen Lump sum $950.00
2 Bathroom Lump sum $1,400.00
Service Balcony Lump sum Inclusive
4 WALL
A To supply and lay ceramic wall tiles :- Lump sum $2,400.00
2 Bathroom
B To supply and install half-height plaster board partition :- Lump sum $100.00
Bedroom 2
C To supply and install Plaster board partition c/w wall paper :- Lump sum $400.00
Master Bedroom
D To seal up existing recess area in plaster board finish :- Lump sum $360.00
3 Bedroom
5 CEILING
A To supply and install L-box:- Lump sum $580.00
Living
B To supply and install false ceiling :- Lump sum $400.00
Foyer
Passageway
6 DOOR
A To supply and install wrought iron main gate :- 1 no $430.00
Main Entrance
B To supply and install lockset for existing main door :- Lump sum $100.00
Main Entrance
C To supply and install veneer door :- 4 nos $1,120.00
3 Bedroom
Store
D To supply and install fixed tempered glass panel :- 2 nos $960.00
( Size : 1600mm x 2550 mm / 800mm x 2550 mm )
Study
E To supply and install fixed tempered glass panel and swing door :- 1 no $2,300.00
Kitchen Entrance
F To supply and install alum. acrylic bi-fold door :- 2 nos $400.00
Common Bath
Service Balcony
F To supply and install tempered frosted glass swing door :- 1 no $650.00
Master Bath
G To supply and install tempered glass shower screen:- 2 nos $900.00
2 Bathroom
7 WINDOW
A To supply and install WPC casement window w/tinted green Lump sum $3,450.00
glass :-
Living
Kitchen
Service Balcony
Study
3 Bedroom
B To supply and install WPC alum.window grilles :- Lump sum $210.00
Service Balcony
C To supply and install WPC adjustable lourve window :- Lump sum $250.00
Common Bath
8 PLUMBING
A To supply and install stainless steel cold pipe:- Lump sum $650.00
Kitchen
2 Bathroom ( Hot point at shower area )
B To install sink and tap :- 1 no $80.00
Kitchen
C To install WC :- 2 nos $200.00
2 Bathroom
D To install basin and tap :- 2 nos $160.00
2 Bathroom
E To install storage heater :- 1 no $80.00
1 Bathroom
* Please note that the prices do not include the supply of the necessary bath and sanitary ware
9 ELECTRICAL
A 5-room electrical re-wiring package Lump sum $2,450.00
- 18 x Light wiring & points
- 2 nos. water heater point
- 3 nos TV points
- 1 no. air-con point
- 3 nos Tel. Points
- 1 no. MCB board
- Installation of lights
- 10 nos. double points
- 3 nos. single points
- 2 sets boarding earth
10 PAINTING WORK
A To furnish wall with Nippon Easywash for the Lump sum $1,350.00
whole house 5 colours inclusive of white
B To paint frame & pipings Lump sum Inclusive
C To revanish or paint main door Lump sum Inclusive
11 CARPENTRY
A LIVING
a Design and install TV feature wall & console in laminate 6 ft $1,500.00
finish
b Design and install Full-height shoe rack in laminate finish 5 ft $1,100.00
B STUDY
a Design and install Low-height cabinet in laminate finish at recess 8 ft $720.00
area
C KITCHEN
a Design and install kitchen cabinet (Top and bottom ) 27 ft $2,700.00
with ABS trim door
Internal cherry finish
Stainless steel dish drainer
Designer handles
b To supply and install solid surface work top 14 ft $980.00
c To supply and install solid surface counter top 6 ft $1,260.00
d To supply and install full height mirror Lump sum $700.00
e To supply and install tempered glass backing 20 ft $1,800.00
D MASTER BATH
a To supply and install vanity top with mirror Lump sum $800.00
12 MISCELLANEOUS
A Acid washing for new homogeneous flooring Lump sum FOC
B Window & general cleaning for whole house Lump sum FOC
TOTAL AMOUNT: $38,930.00
LESS : $1,430.00
GRAND TOTAL: $37,500.00
Mine also quite expensive...
DEMOLISHING WORKS
To supply labour & materials to hack existing floor tiles for balcony - $150
To supply labour & materials to hack existing wall tiles for balcony - $200
To supply labour & materilas to hack existing sliding door at balcony - $100
To supply labour & materials to hack existing wall, door & door frame at study room - $200
To supply labour & materials to hack existing wall tiles at kitchen, bath / wc 1 & 2 - $1500
To supply labour & materials to hack existing main entrance - $80
To supply labour & materials to remove existing wrought iron gate - FOC
To supply labour & materials to hack existing stove support at kitchen - $100
To supply labour & materials to hack existing cornices **** - $100
Haulage fee for the whole house - $400
Removal of debris from site with skip tank - $500
WET WORKS
To supply labour & materials to top up access area & balcony with EPL foam - $450
To supply labour & materials to lay homogenous floor tiles at balcony - $450
To supply labour & materials to construct 50mm base for kitchen cabinet,
washing machine & fridge base - $320
To supply labour & materials to lay homogeneous wall tiles at bath / wc 1 & 2
(based on S$2.00psf for materials cost) - $3000
To supply labour & materials to lay homogenous floor tiles at bath / wc 1 & 2
(based on S$2.00psf for materials cost) - $900
To supply labour & materials to lay homogenous wall tiles at kitchen
(based on S$2.00psf for materials cost) - $4000
To supply labour & materials to lay homogenous floor tiles at kitchen
To supply labour & materials to erect 3ft wall with hollow block at kitchen - $300
To supply labour & materials to lay waterproofing at kitchen - $200
To supply labour & materials to lay waterproofing at bath / wc 1 & 2 - $300
To supply labour & materials to polishing existing marble for whole house - $2200
To suppply labour & materials to install stainless steel dustbin - $220
To supply labour & materials to lay matching compressed marble at proposed
area at study - $450
To supply labour & materials to lower down entrance of bath / wc 1 & 2 with
hollow block & hydric mesh - $300
To supply labour & materials to touch up damaged door frame at balcony - $200
To supply labour & materials to hack 02 x cement arch **** - FOC
TIMBER WORKS
To supply labour & materials to install 04 x classic doors for bedroom with
standard lockset - $640
To supply labour & materials to install 01 x main door & door frame with
lockset for main entrance / Fire rated - $1100
PLUMBING WORKS
To supply labour & materials to install cold stainless steel piping for the whole hse
To supply labour & materials to install hot stainless steel piping for the whole hse
To supply labour to install 02 x pwc & 02 x basin at bath / wc 1 & 2
To supply labour to install 01 x gallon heater at bath / wc 1
To supply labour to install 02 x bidet spray & 01 x washing machine tap
To supply labour to install 02 x sets of bath accessories at bath / wc 1 & 2
To supply labour to install kitchen sink & sink tap Lump sum $1500
PAINTING WORKS
To supply labour & materials to paint whole house with ICI / NIPPON paint - $1400
To supply labour & materials to lay corrugate paper for the whole house flooring - $200
To supply labour & materials to chemical wash for the whole house flooring - $300
CEILING WORKS
To supply labour & materials to plaster ceiling at kitchen, bath / wc 1 & 2 - $600
To supply labour & materials to box up 04 x door pelmet with plaster board - $320
To supply labour & materials to install false ceiling at study with plaster board - $700
To supply labour & materials to install simple cornices **** - $300
CARPENTRY WORKS
To supply labour & materials to install 26ft designer kitchen cabinet with solid
laminate / veneer c/w 01 x dish rack. 01 x chest of drawers & 01 x cutlerly tray - $2600
To supply labour & materials to install 8ft granite worktop on kitchen cabinet - $960
To supply labour & materials to install 01 x island unit with solid laminate at
kitchen - $750
To supply labour & materials to install granite top on island unit - $900
To supply labour & materials to install counter top with granite finish - $800
To supply labour & materials to install plaform with laminated flooring at study - $1600
ALUMINUM WORKS
To supply labour & materials to install 02 x aluminum bifold door at bath / wc
1 & 2 from BESGLAS - $560
To supply labour & materials to install aluminum sliding door with frosted glass
at kitcehn entrance - $660
To supply labour & materials to install wrought iron main gate with standard
lockset - $550
To supply labour & materials to install aluminum casement / sliding window with
tinted glass for balcony, study & bedroom 2 - $1800
To supply labour & materials to install BN / NA aluminum window grilles
for whole house - $1400
To supply labour & materials to install adjustable aluminum louvers with wired
glass at bath / wc 1 & 2 - $360
Total: $37,520
