Hi, I just got a quotation from my ID. Not sure if expensive or not. Any comments?
The quotation is for a 5rm resale unit.
I will most likely get a re-quote coz budget only ard 30-35k. :):P:P
___________________________________________________________________________________
S/N DESCRIPTION
A HACKING
1 Hack & dispose off existing floor tiles at :-
- Living & dining
- Private Balcony
- Studyroom
- Storeroom
- 3 x bedrooms
- Kitchen
- Master toilet
- Common toilet
- Service Balcony
2 Hack & dispose off existing wall tiles at :-
- Master Toilet
- Common Toilet
3 Dismantle all unwanted cabinets & fixtures
4 Dismantle existing door frame at toilets & plaster smooth
5 Dismantle existing toilet bowls & basins
6 Hack whole house windows
B TILING WORK
B1 Floor tiles
1 Supply labour & materials to lay homogeneous floor tiles **** & dining
& storeroom
- tile size : 600mm x 600mm
- includes skirting
2 Supply labour & materials to lay cement screeding for 3 bedrooms
3 Supply labour & materials to lay laminated floorings for 3 bedrooms
& studyroom
- includes skirting
4 Supply labour & materials to lay homogeneous floor tiles at kitchen
- includes water-proofing
5 Supply labour & materials to lay homogeneous floor tiles at master toilet
- including water-proofing
6 Supply labour & materials to lay homogeneous floor tiles at common toilet
7 Supply labour & materials to lay homogeneous floor tiles At private balcony
B2 Wall tiles
1 Supply labour & materials to lay ceramic wall tiles at master toilet
- to full ceiling height
2 Supply labour & materials to lay ceramic wall tiles at common toilet
B3 Others
1 To construct 50mm height kitchen cabinet base
2 To construct 50mm height fridge base with tiles surface
3 To construct 50mm height w/machine base with tiles surface
4 Construct 50mm height shower kerb at master toilet
5 Construct 50mm height shower kerb at common toilet
C PLUMBING & SANITARY
1 To replace whole house s/steel pipings ( hot & cold )
2 To extend sink & w/machine in/outlet
3 To connect sink & w/machine in/outlet
4 To install 2 x toilet bowls & basins ( Labour only )
5 Supply labour to install bathroom accessories & heater
D ALUMINIUM WORK
1 Supply & install aluminium windows for whole house
- Silver/ Bronze
- Normal glass
- Casement Panels
2 Supply & install lourves windows for both toilets
3 Supply & install 3 x aluminium bi-fold doors at toilets
- Acylic glass
4 To supply & install 10mm thick tempered glass shower screen at
master toilet
E PLASTERING & PAINTING
1 Plastering of kitchen wall
- over existing wall tiles
2 Whole house painting - ICI/Nippon
- No limitation to the no. of colours
3 Painting of kitchen wall
F FALSE CEILING & L-BOX
1 To install false ceiling design ****
2 To install false ceiling design at dining
3 To install false ceiling at bedroom passageway
4 To install false ceiling design at master bedroom
G HAULAGE FEE
H ACID-WASHING
I CARPENTRY WORK
a) Living Room
1 To design, construct & install feature wall for tv,using laminates
- Approx. 6 Ft x ceiling height
2 To design, construct & install tv console using laminates
- Approx. 6 Ft
3 Supply & install 3 x bedroom doors & 1 x storeroom door
- Solid classic doors
b) Master Bedroom
1 To design, construct & install built-in wardrobes using laminates
- internally with hanger rod, drawers & adjustable shelvings
- Sliding door panels
- Aluminium frame with sand-blasted / spray-paint glass
2 To design, construct & install LCD feature wall using laminates
- Approx. 3 Ft x ceiling height
- 2 sided design
3 To supply & install solid surface vanity top
- with 4" front profile
- Approx. 5 Ft
4 To design, construct & install suspensed cabinets at vanity using laminates
- Approx. 5 Ft
5 To supply & install wall-to-wall mirror
c) Studyroom
1 To supply & install 10mm thick tempered glass fixed panel cum
casement door
- Approx. 9 ft x 7ft height
- includes top box-up
d) Bedroom 2
- Approx. 7 Ft x ceiling height
- Casment door panels
e) Kitchen
1 To design, construct & install built-in kitchen cabinets using laminates
with veneer edgings
- Approx. 33 Ft
- internally with adjustable shelvings
2 To supply & install s/steel dish-drainer
3 To supply & install 1 no. of cultery tray
4 To supply & install 1 set of drawers ( BLUM System )
5 To supply & install 3 nos. of sand-blasted glass doors
- aluminium frame
6 To supply & install aluminium v-handles
7 To supply & install solid surface top ( 15 ft )
8 To install sink, cooker hood & hob ( Labour only )
9 To design, construct & install partition at beside fridge,using laminates
10 To supply & install self-closing hinges for base cabinets
TOTAL AMOUNT : $46,600
Edited by toonsim
S/N DESCRIPTION
you never mention your flat size, cos everything measured in units aand quote in units, becareful when you ask for quote, give them the exact measurements so wont off to much else later they ask you to top up
i measured my windows to the exact cm and give slight allowance, but the contractor measure in ft, so he overlook the measurements and under quote a bit.. so you must becareful
always ask for per unit charge are how much so they cannot ask you to top up the diff
A HACKING
- Living & dining
- Private Balcony
- Studyroom
- Storeroom
- 3 x bedrooms
- Kitchen
- Master toilet
- Common toilet
- Service Balcony
- Master Toilet
- Common Toilet
3 Dismantle all unwanted cabinets & fixtures you never mention no of fixtures, careful cost every single item remove is a charge
B TILING WORK
B1 Floor tiles
1 Supply labour & materials to lay homogeneous floor tiles **** & dining check the tiles price capped at what price
& storeroom
- includes skirting
& studyroom
- includes skirting
B2 Wall tiles
B3 Others
D ALUMINIUM WORK
- Silver/ Bronze
- Normal glass
- Casement Panels check your window length very impt
2 Supply & install lourves windows for both toilets abt $320
- Acylic glass
master toilet
G HAULAGE FEE
H ACID-WASHING
I CARPENTRY WORK
a) Living Room
- Approx. 6 Ft
b) Master Bedroom
- 2 sided design
- Approx. 5 Ft
- Approx. 5 Ft
c) Studyroom
casement door
d) Bedroom 2
e) Kitchen
with veneer edgings
- Approx. 33 Ft
- aluminium frame
hee all without units so i think ppl will find it hard to comments can only put notes for you to take note only..
get more quotes the best comments..
Oh paiseh.. My place is a 5rm resale.
As for the units, we are not sure too. Yet to get our place but want to have a feel of the reno costs.
then you will easily kena chop by ppl.. if you hav time, go do more search, see the designer and contractors thread, they are my search :)
do more at least 5 ok..
then you will easily kena chop by ppl.. if you hav time, go do more search, see the designer and contractors thread, they are my search :D
Thanks. I will definitely be looking around for more quotes. :)
I would also like some comment on m y quote. Mine is a 4room new flat, abt 90sqm
LIVING, DINNER AND HOSUEHOLD SHELTER HALL
1) Supply & install palster false ceiling with cove light effect and curtain pelmet - S$1050
2) Supply & lay 600mm x 600mm gloss homogenous floor tiles with skirting - S$2150
3) Fabricate & install 2.4m length low tv console cum dining bench in venner finishes - S$1440
4) Fabricate & install 2.35m length feature wall in venner with tea glass provision LCD - S$1680
5) Fabricate & install 2.6 length venner feature wall to concealed of existing household shelter c/w internal storage - S$1870
5) Supply & install full height gypsum board partition wall at household shelter area - S$320
MASTERBEDROOM
1) Supply & lay 600mm x 600mm gloss homogenous floor tiles with skirting - S$1250
2) Supply& install plaster false ceiling with cove light effect and certain pelmet - S$575
3) Fabricate & install 1 no side board with drawers in laminate finishes - S$280
4) Supply & install full height gypsum board partition behind bed area to flush with existing lintel - S$300
5) Hack existing hollow block panel at tv area a/c cement smooth screeding - S$550
6) Supply & install full height gymsum board partition below existing lintel at tv area - S$480
7) Fabricate & install 3.5m length full height sliding wardrobes in laminated finishes - S$2650
8) Fabricate & install 2.2m low wall mounted cabinet in venner finishes for audio system - S$900
9) Fabricate & install 1.8m length lighting pelmet with glass top in selected venner finishes - S$720
10) Supply & install 2.3m length fabri headboard with timber backing c/w lighting effect - S$1350
KITCHEN
1) Construct 50mm washing machine base c/w inlet and outlet pipe - S$200
2) Construct 50mm fridge base with HDB tiles finishes - S$180
3) Fabricate & install 3.1m length top storage cabinet in laminate finishes c/w colour glass door with alum framework - S$1350
4) Fabricate & install 4.7m length l-shape bottom storage cabinet in laminate c/w 1 chest drawers - S$1860
5) Supply & install 3.1m length tempered colour glass inbetween cabinet area - S$600
6) Construct 1m height hollow block wall c/w cement smooth screeding - S$600
7) Supply & install I-shape 4.7 length solid surface c/w square profile - S$1395
8) Supply & install 1 no fix with 10mm tempered swing glass door in tea colour c/w steel handlers - S$1500
9) Supply labour for cement screeding c/w applying of waterproofing provision for painting finishes - S$950
BEDROOM 2&3
1) Supply & lay 600mm x 600mm gloss homogenous floor tiles with skirting - S$1850
2) Fabricate & install 3.5m length study table with drawers in laminated finishes c/w flip up storage for concealed of wires - S$1495
3) Fabricate & install 3.5m length top storage cum display cabinet with light pelmet in laminate finishes - S$1380
MASTER BATHROOM
1) Supply labour & material for overlaying non slip homogenous floor tiles for both bathrooms - S$1100
2) Supply & install 1.5m length solid surface top c/w square edge profile w/o sink for master bathroom - S$450
3) Fabricate & install 1.5m length wall mounted storage cabinet in laminate finishes for master bathroom - S$600
4) Dismantle existing sink at master bathroom c/w touch up of HDB tiles - S$250
5) Supply & install 1.5m length horizontal mirror with light pelmet at master bathroom - S$600
6) Supply & install wall to wall 10mm tempered glass frameless shower screen with round handler at master bathroom - S$720
PLUMBING WORKS
1) 2 no. instant heater - S$150
2) 2 no bathroom sink with tap - S$80
3) 2 set of toilet accessories - FOC
4) 1 no kitchen sink with tap - S$85
OTHERS
1) Labour for painting of whole unit with ici emulsion include doors pipes & gates - S$1200
2) Applying of sealer at new false ceiling area - S$120
3) Supply & lay protective cardboard for whole house flooring - FOC
4) Supply acid/chemical for general washing (2trips) - FOC
TOTAL : S$36,280
MASTERBEDROOM
7) Fabricate & install 3.5m length full height sliding wardrobes in laminated finishes - S$2650 (yours abt $230 per foor run, how you find?)
KITCHEN
2) Construct 50mm fridge base with HDB tiles finishes - S$180 (i think a bit high for frigde only is it?)
3) Fabricate & install 3.1m length top storage cabinet in laminate finishes c/w colour glass door with alum framework - S$1350 (don quite understand, actually your quotation so much diff from what others quote, urs measured in metre leh, most measured in ft, be thorough with your quote, this item is $130 per foot run)
(this item is $120 per foot run ba)
6) Construct 1m height hollow block wall c/w cement smooth screeding - S$600 (mine is only $320 c/w tiles leh, they always put 63mm thickness hollow block, yours quote very weird, see how others comments too ok)
7) Supply & install I-shape 4.7 length solid surface c/w square profile - S$1395 (getting quite unable to understand new terms here, wat is sq profile this is abt $90 per foot run, pls check your brand ok)
BEDROOM 2&3
MASTER BATHROOM
PLUMBING WORKS
OTHERS
1) Labour for painting of whole unit with ici emulsion include doors pipes & gates - S$1200 no of paints colour you can select?
TOTAL : S$36,280
sorry so many terms don understand, but seems like you are doing quite a design in your flat :notti:
Wah, seems like mine is on a very high side.. I'm really unsure tat's y i posted my quote here. Think i really have to discuss with my FH before getting the agreement signed! Another doubt, will the final quotation from ID include material used and how much per sq ft?? Any idea??
you must make them write down now already.. most wont auto put down lo..
hav you try the popular companies in this forum?
I've source for 3. Apparently we like his design very much and he is very daring with colours tat's y chances are on the high side on confirming. Need your advise if i'm able to negotiate for better deals on certain items.
You should insist your ID to put down all quantity as any discrepency, the rate can be easily computed and discrepency can be determine irregardless of more or less. This will be fair to both parties. Same goes to material used. The final measurement on plan as compared to site should be within the limit of 5% which is acceptable. Anything more than that is a discrepency and should be rectify immediately with you ID to prevent arguement
Hi Rainbow04
Mine is also new 4 room flat - 90sqm. Let me share my quote for people to comment as well.
Masonry works
1. Supply & lay 600mm x 600mm homogenous tiles **** and dining room - $2,350
2. Supply & lay skirting (homogenous tiles) **** and dining - FOC
3. Supply & lay liminating floor at 3 bedroom and all skirting at 3 bedroom - $1,700
4. Supply & lay homo or ceramic at storeroom area - $350
5. Alteration of main gate - $70
6. Alteration of main door - $30
Kitchen area
7. Construct cement motar base for kitchen cabinet c/w side tiling $250
8. Construct fridge, washing machine base with tiles - $250
9. To supply & install piping for kitchen & washing machine $120
10. To supply & lay floor tiles at kitchen using tiles - $950
11. To apply waterproofing at kitchen floor K11 - $180
Both toilet
12. To supply & overlay floor tiles at both toilets - $750
13. To apply waterproofing at both toilets floor K11 - $150
14. Supply & install tempered flass shower screen at both toilet - $900
15. Supply & install vanity top using granite top at master toilet only - $540
16. Supply & install lower cabinet, mirror wall to wall and display glass shelving - $650
Plumbing work
17. Supply & install new s.steel piping for whole house (one way) - $650
18. Supply labour to install two set of instant heater - $120
19. Supply labour to install toilets accessories - both toilets and kitchen - $80
20. To supply & install piping for kitchen & washing machine - $120
Ceiling works
21. To supply & install L box light holder / false ceiling **** / dining and passage way - $1450
22. To supply & install L box light holder / false ceiling at master bedroom - $680
23. To supply & install simple cornies ceiling at 2 bedroom - $400
Painting works
24. Painting of whole house using ICI / Nippon emulsion paint (no color limit) - $1,100
25. Painting all door / frame / gate / piping etc - $150
Door
26. Supply & install 3 set of bedroom door - solid veneer door with s. steel - $750
Other works
27. Supply & install alum window follow the existing color for whole house - $800
28. Houlage fee & general cleaning and 2 time acid washing for whole house flooring - $350
Carpentry work
29. Supply & install kitchen cabinet using solid pry door with 1mm ABS trimming height pressure laminate
Est no. of foot run 12ft top 9 ft bottomr (add cost per foot run $80) - $1,680
30. Supply & install surface granite top at kitchen work top 9 ft. (add cost per foot run $90) - $810
31. Stainless steel disk rack 1 set come with s. steel shelving bar display - $900
32. Supply & install full height tempered glass divider - $900
33. Supply & install long bench with back rest, with full height mirror to ceiling 7ft - $980
34. Supply & custom made glass dining table 1200mm x 750mm with wooden leg & granite top - $1,600
Living & dining
35. Supply & install feature wall with display cabinet, mirror, feature wall design, 14 ft - $3,800
36. Supply & install feature wall with mirror (shoe cabinet full height with door) 8 ft - $1,700
Master bedroom
37. Supply & install partition feature wall c/w side table bedhead design 10ft - $2,600
38. Supply & install sliding wardrobe c/w design 8 ft - $1,900
39. Supply & install platform bedbase for king size bed - $850
Bedroom 2
40. Supply & install study table top and bottom 14 ft - $1,540
41. Supply & install sliding wardrobe c/w design 6 ft - $1,380
Total - $37,410
why your no 41 cost $230 per foot run, why yor no 38 cost more its $237.5, pls check, cos you pay $60 more on no38
i suggest you all wan try a&d price? you might see some diff..
