mariner
Can Recommend A Toilet Window Changing Contractor?
Hi! Very new to this forum. Need recommendations from the bros here for a contractor to change my MBR toilet window from a louvre type to something to install with a ventilation fan which I just bought. How much roughly it cost?
Thanks and cheers! :)
Thanks and cheers! :bangwall:
$150-$250
any window contractor will do.
you need wiring also - should cost around $70-$90 to fix a switch outside toilet.
I even DIY a timer ( www.esaver.com.sg ) on the ventilator so that after leaving the toilet/bath, just switch on the timer for 20mins and heckcare about it.
Edited by MaCe
how much does the timer cost? It is easy to install? Mace do u have a pic when installed?
timer only $18.00 homefix and big hardwarestore have it. took me about 1 hour to figure out - it's very easy just that me not that intelligent :notti:
after installation - it's exactly the same way you see in www.esaver.com.sg
oic... dunno easy to install anot?
if you installed the ventilator by yourself then installing this timer is easy.
esaver also has countdown timer switch (adjustable timing up to max 3 hr), just plug into the wall socket, and the appliance just plug into the timer switch... v simple to use and no need to install anything... but of cos also as nice as those built-in timer switch...
mustafa selling it at $12... :yamseng:
Edited by redbottle
mustafa selling it at $12... :P
thats provided you change your WIREs to at least 3m or more - to plug into a socket all the way from the toilet window.
