icebaby
Aircon Quotes (From Aron)
Hi all renotalk members, we are running a special air-con promotion for MITSUBISHI STARMEX:- (Please email aron at aronputt@gmail.com for this promotion)
A) Special Renotalk Price: $3750 nett for Mitsubishi Inverter system 4 (new model, 18kbtu + 9kbtu X 3)
B) Special Renotalk Price: $2899 nett for Mitsubishi Inverter system 3 (new model, 9kbtu X 3)
B) Special Renotalk Price: $2850 nett for Panasonic Inverter system 3 (new model, 9kbtu X 3)
C) Special Renotalk Price for brands like daikin, toshiba, LG etc. Single Split, System 2/3/4 available for both inverter and non-inverter.
* Free & no obligation Site Survey
* Free 2 trips installation (1st trip to run piping, 2nd trip to put up air-cons [if needed])
* Free dismantle and disposal of old air-con
* Free upgrade to Armaflex class “O” 1/2 inch thick insulation,G23 copper pipe,keystone cable (made in singapore),16mm drainage pipe
* Special coordinating work between us and customer’s contractor
* Special appointed installation team
* Special supervising work by head of installer
Terms & Conditions
*All promotion items while stock last
*All prices include HDB standard installation
Thank you,
Aron
aronputt@gmail.com
Hello Aron,
I'm planning to start reno by next week for my new 4rm HDB.
Only doing aircon for MBR, studyroom, and living area.
Please pm details on which system (2,3 or 4?) that i should get and your quotation. As i need to compare with my contractor's contact.
Looking at either Mitsu or Daikin.
Thank you.
Hi Aron,
I am looking at replacing my 2x system 3 non-inverter air con. I am looking at the following inverter configuration.
1. 1x system 4 (3rm + 1 hall)
2. 2x system 2
3. 1x system 3 and 1x system 1
My budget is not more than $3500. Can you recommend and quote me based on the best options? Please send to me my email address : tkcltoh@hotmail.com
Thanks
Regards
Toh
Terms & Conditions
Thank you,
Aron
aronputt@gmail.com
Hi Aron,
I just sent an email to aronputt@gmail.com to request for a quotation. looking forward to hear from you.
Regards
PK
Terms & Conditions
Thank you,
Aron
aronputt@gmail.com
Hi guys, need some advice.
I have three bedrooms that I want to replace the aircons. My contractor quoted me Mitsubishi electric starmex inverter 1 to 1 systems. 2 sets of MUY-GE13VA, MSY-GE13VA for 2 bedrooms; and 1 set of MUY-GE18VA, MSY-GE18VA for the bigger bedroom.
Is it better to have three 1:1 systems or have a single multi-split 1:3?
Thanks in advance.
Terms & Conditions
Thank you,
Aron
aronputt@gmail.com
Hi Aron,
Pls give me a quote for the below:
Mitsubishi star ex inverter system 3 (9k btux3)
Mitsubishi starmex inverter system 2 (18k + 12k btu)
I need total 5 units for my whole house, going to start my Reno this fri, pls reply ASAP, thanks!
I think Panasonic having some promotion now.
I just confirm with my installation of aircon for my new flat from Tim.
Panasonic Multisplit CU-3S27MKZ
3 unit Inverter Fancoil S9NKZW
1 unit " " S18NKZW
Upgrade to armaflex half inch thick insulation, G22 copper pipe, 16mm drainage and 2way trips
one year warranty workmanship and aircon equipment and five years standard warranty for compressor at $3429 incl gst.
can advise Daikin, Multi split, system 4, inverter, R410a and the follow additional upgrades,
what is the total price ?
Terms & Conditions
Thank you,
Aron
aronputt@gmail.com
Hi Aaron, email you but no response, kindly quote for starmex inverter system 4, 24k btu x 1, 9k btu x 3.
Terms & Conditions
Thank you,
Aron
aronputt@gmail.com
Hi Aron,
Looking for configuration like
Mitsubishi Inverter system 4 ( 18kbtu + 12btu + 9kbtu x2) for my 5 room flat
Please recommend & quote
Hi Aron,
Appreciate if you could quote me on:
Daikin System 4 Inverter Aircond
9kBTUx3 + 18kBTU
Panasonic eco-navi System 4 Inverter Aircond
9000BTUx3 + 18kBTU
*with upgrade to Armaflex class “O” 1/2 inch thick insulation,G23 copper pipe,keystone cable (made in singapore),16mm drainage pipe
* 2 trips installation
Thanks
Dear all, pls kindly drop me an email at aronputt@gmail.com for any enquiry. Currently serving my reservist, only able to access my email. Thanks
B) Special Renotalk Price: $2799 nett for Panasonic Inverter system 3 (new model, 9kbtu X 3)
Terms & Conditions
Thank you,
Aron
aronputt@gmail.com
I just collected the keys for my BTO in Punggol. Am planning to install aircon in 2 bedrooms and the living room. Should I go for sys 3 or have 2 compressors (if it is allowed)? I am considering Daikin, Panasonic or Mitsubishi HI. Any recommendations, anyone? Thanks ;)
in my opinion, one compressor is good enough. Unless you need all 3 units to be running at the same time.
