icebaby
Aircon Quotes (From Aron)
hi Aron, just emailed u for a quotation on system 3 inverter system. Hope to hear from u soon.. =)
I have just PMed you.
Thank you,
Aron (aronputt@gmail.com)
I am too looking for inverter type of aircon, system 3 for all my 3-bedrooms.
Would be keen to know know the prices for Mitsubishi and Panasionic. Which model is better?
Thanks
Kooky use mit better... definitely much more cool... there is currently 2 type... 1 is heavy industrial and another is electic... u wan can pm me I tell u more...
I have done up my 4 room recently and was satisfied with the contractor. My final choice was daikin and my quotation was
Daikin inverter system 4 ,
1 x 18k btu fancoil
1 x 12k btu "
2 x 9k btu "
1 x 29k btu compressor
1 x stainless steel bracket
Warranty given ,
Fan coil 1 year
Compressor 5 years
Workmanship 3 months
Servicing of air-con provided @ $40/unit (minimum 2 unit)
- washing & cleaning + top-up of gas if required
Total price came up to $4550. I have made comparison on my contractor's quote with some big electrical stores and the prices were quite competitive like a few hundred difference. The plus point is the contractor's quote does not include gst (because he is a freelance) unlike the big electrical store and i saved another few hundred. :rolleyes:
Initially i wanted to go for Mitsubishi because the quotation is cheaper ($4100) but after seeing my friend's air-con always having problems, i decided to go for daikin as advised by the contractor. Workmanship wise is still acceptable and everything were completed within a day. I cant comment much as i just started using.
hi aron,
can you quote me system 3 inverter Mitsubishi electric Starmex, Mitsubishi heavy industries and Panasonic eco-navi pls?
thanks.
zzlp@ymail.com
hi aron,
thanks.
zzlp@ymail.com
I have just emailed you.
Thank you,
Hi Aron,
Intend to a/c our three bedrooms. We will use only at night. And when we do, all three will probably be on at the same time.
For this usage, would u recommend inverter or non-inverter?
Also, we are considering Mitsubishi, Daikin, panasonic and Toshiba.
Any comments?
Give me best price. Need to get installed by end of the month.
Thanks!
shamine1314@gmail.com
Hi Aron,
Can you quote me system 4 inverter Mitsubishi electric Starmex, Mitsubishi heavy industries and Daikin pls?
thanks.
Thank you,
Hi Aron,
Any comments?
Thanks!
Thank you,
Thanks bro. So total 4 units aircond?
yes, total is 4 aircon. 18k for living room, 12k for master bedroom, 2 x 9k for common bedrooms. loving this daikin air-con especially at night because its really quiet and can sleep peacefully as im a light sleeper.
