icebaby
Aircon Quotes (From Aron)
  blissxx said:
the sales guy say inverter or non-inverter not much difference as air con consumes lare amount of electricity anyway...
Under certain operating conditions, inverter air-con system uses less electricity than non-inverter version.
NEA knows.
However! Inverter air-con systems cost > $1,000 more than non-inverter versions.
It is quite apparent that :fire: this sales personnel know little about the products that he is promoting....
  blissxx said:
Hi I saw the same prmo too.. must use UOB card to pay rite?
How is the aircon? e.g coolness, noise level etc...
btw do u know the model of the sony digi cam?
tks
Oops wrong place to reply
anyway Hi Goldlim
How is the aircon? e.g coolness, noise level etc... the sales guy say inverter or non-inverter not much difference as air con consumes lare amount of electricity anyway...
tks
Yea .. I used UOB 24 mths installment 0%. Sony digicam 7.2 megapixel. forget the model alr. but seen before from the web. as for coolness and noise level not yet installed.. Hahaha.. Installing this sat. :)
Natural cool have promotion for Panasonic sys 3 ,non inverter for $1490 PLUS $200 ntuc voucher.Model : xxx HKH (Inclusive installation,removal and normal piping,insulation)
Add $180 for thicker insulation
random check with other shop abt @2k.
Hi All,
We would like to install a new aircon. Any one care to advise what should we pay for installation charges?
Since all routing bracket are there what else should we pay....???
Sorry reading the whole forum made me very confuse. So many items. :unsure:
TIA
Guest
This forum has been an invaluable source of research for me. Hope to pay it forward!
Mitusbishi Electric System 2 (non-inverter) MUX-3D23VD - $1670 from Hong Tar
The above includes installation and steel bracket. Did not upgrade the insulation. Sorry I'm not familiar with the technical terms.
:yamseng:
Guest
  henrywoo1978 said:
Hi SixYardBox,
I remember the default insulation is already 1/2" thick, correct me if I am wrong. So by right no need to upgrade.
Hi henrywoo1978
The bad handwriting on the invoice either says 5/8" or 3/8". Does that mean 1/2"?
Salesperson said it was ok, so trusted her. *Fingers crossed*
  tiffanynip said:
Armaflex insulation is the better choice.
I was given a quote of $1600 for mitsubishi non inverter system 3 using R22, 3 x 10k unit. Is that expensive? Going to reuse the existing pipe and no bracket needed as well.
my latest air con pricing from GC.
mitsubishi Starmex system 4. consists of
1xMXY-4A28VA
3x MSXY-GA10VA
1x MSXY-GA22VA
bracket
upgrade to Armaflex 1/2" insulation
upgrade to copper Gauge 22 piping
16mm drainage pipe
2 times installation
extended 5 years warranty
12month 0% installment
removal of existing system 3 aircon
the bomb is $4.3K
Installation done, cross finger no problem... zzzzzz
