icebaby
Aircon Quotes (From Aron)
Hi, please give me a quote for the following:
- System 4: 9k X 3 + 18K X 1
- System 4: 9k X 3 + 22K X 1
Prefered brand of the spec above:
1. Mitsubishi Electric
2. Carrier
3. Daikin
Quote shall include installation with:
- Armaflex 1/2 inch insulation
- G22 copper pipe
- keystone wire
- 16mm drainage pipe
- stainless steel bracket
Hi Aron,
Can I get a quote for inverter mitsubishi starmex system 1 (single unit) and inverter mitsubishi starmex system 3 for a 5 room HDB Bto? Can you also advise the capacity required for the single unit which is to be placed at the living room and dining area?
Appreciate it if you could let me know the materials for installation, payment terms, warranty and any other costs involved.
Thank you.
Hi Aron,
Please advise how thick will the trunking be if i use:
G23 copper pipes,
1/2" Class "0" Armaflex insulation,
16mm drainage pipe?
Also, the size of the trunking if i use the thicker G22 copper pipes instead?
Is G23 suffice/suitable for HDB?
Thanks.
2. Carrier
3. Daikin
- G22 copper pipe
- keystone wire
I have just PMed to you.
Thank you,
Aron (aronputt@gmail.com)
https://www.facebook...355281117982556
Hi Aron,
Thank you.
Thank you,
