lifestyle 0 Report post Posted August 1, 2007 Hi everyone,Need urgently advice on the following:Would like to find out what is the different between Die Cast Aluminium Vs Die Cast Chrome for the spot light material?Which is better & why?Thanks Share this post Link to post Share on other sites
l_club23 0 Report post Posted August 1, 2007 Hi everyone,Need urgently advice on the following:Would like to find out what is the different between Die Cast Aluminium Vs Die Cast Chrome for the spot light material?Which is better & why?ThanksI am guessing its the finish?Generally chrome has the glossy shiny look and aluminium has the matted brushed look? Share this post Link to post Share on other sites
zirhk3355 1 Report post Posted August 1, 2007 There is no die-cast chrome.Chrome is a form of plating (akin painting) on metal/plastic material, which gives it a shiny look. The material can be any kind, you can't see if its good when its covered by chrome. And since its a plating, just like paint or coating, it has the the tendency to corrode. Somemore its exposed to heat.In that sense, I would feel that aluminium is better, since it has better resistance to heat, it is a whole piece of material instead of just a plating on some unknown metal alloy.But on the other hand, chrome would look nicer because of its shiny surface. Maybe if a good job is with the chrome plating on good material, then it can last lor... Share this post Link to post Share on other sites
lifestyle 0 Report post Posted August 2, 2007 Many thanks l_club23 & zirhk3355. Agree with your comments.Just not sure which supplier to take. Once offered Die Cast Alum with ballester from Europe (cannot choose which brand) and another supplier offered Die Cast Chrome with ballester (ATCO i believe) made from Australia (which is normally better).Both are offerring Osram tubes.Which is more important do you think in decision process as both price come out to be the same...The die cast materials or ballester/bulb?Thanks again. Share this post Link to post Share on other sites
bullet 0 Report post Posted August 2, 2007 There is no die-cast chrome.Chrome is a form of plating (akin painting) on metal/plastic material, which gives it a shiny look. The material can be any kind, you can't see if its good when its covered by chrome. And since its a plating, just like paint or coating, it has the the tendency to corrode. Somemore its exposed to heat.In that sense, I would feel that aluminium is better, since it has better resistance to heat, it is a whole piece of material instead of just a plating on some unknown metal alloy.But on the other hand, chrome would look nicer because of its shiny surface. Maybe if a good job is with the chrome plating on good material, then it can last lor...Expert siah.......Truly aluminium die cast is better as Halogen emit alot of heat. Chrome die cast is usually made of cheap iron but chrome to give the product a shiny metalic look. When expose to heat, the chrome will either peel off or tanished with black spot surfacing.....very ugly Share this post Link to post Share on other sites
lifestyle 0 Report post Posted August 2, 2007 Thanks bullet This is also what i heard (regarding black spots in the long run ) from other lighting shops.Expert siah.......Truly aluminium die cast is better as Halogen emit alot of heat. Chrome die cast is usually made of cheap iron but chrome to give the product a shiny metalic look. When expose to heat, the chrome will either peel off or tanished with black spot surfacing.....very ugly Share this post Link to post Share on other sites
Warrior88 0 Report post Posted August 2, 2007 Expert siah.......Truly aluminium die cast is better as Halogen emit alot of heat. Chrome die cast is usually made of cheap iron but chrome to give the product a shiny metalic look. When expose to heat, the chrome will either peel off or tanished with black spot surfacing.....very uglyMy deco sense to decide the focus of attention in each area.Usually for hall, it will be the Video display backdrop..etc.Unless you wish to protray those starry effect on yr ceiling.But then again, it may looks like UFO circling the universe.Downlights enhance objects ( makes object not looks flat )It is the lights, not the fitting that does the job. I won't ought for fancy fittingSymetrical & simple makes ceiling blend with yr deco.Also, chrome material, if contact with hands ( moisture ) will also tanished.First 3 months very nice, after that gold & black. Share this post Link to post Share on other sites
MaCe 3 Report post Posted August 2, 2007 apart from the casing - go for 12V halogen - another type of lamp also looks like halogen but it's using 230v - more energy consuming. Most salesman will tell you all same same halogen.I believe the 230v ones got a different name.12V halogen lamp 's 2 "legs" are just 2 sharp pins.the other type(230v) the 2 "legs" got a tiny round stub.I even went to osram distri to buy the special DecorStar-IRC halogen lamp(energy saving halogen). But it costs $8 bucks each Share this post Link to post Share on other sites
raincole 0 Report post Posted August 2, 2007 Is energy-saving lights dimmer than the normal fluroscent lights? Cos my HB wants to use the fluroscent light whereby I'm concerned abt the electrical bills $$. Share this post Link to post Share on other sites
MaCe 3 Report post Posted August 2, 2007 (edited) Is energy-saving lights dimmer than the normal fluroscent lights? Cos my HB wants to use the fluroscent light whereby I'm concerned abt the electrical bills $$.energy saving bulbs are not dim, except for those no name brands. Go for either osram or philips, nothing else. If you want bright bright types, go for those "curled" bulb, philips called them TORNADO, they are very bright!no worries, for fluroscent, get them to change the ballast to electronic ballast($12-$35).save a lot of electricity. Edited August 2, 2007 by MaCe Share this post Link to post Share on other sites
l_club23 0 Report post Posted August 2, 2007 Yup Chrome will get tarnished due to our humidity.On another note, do T5 tubes consume less electricity than flourescent? Share this post Link to post Share on other sites
MaCe 3 Report post Posted August 2, 2007 Yup Chrome will get tarnished due to our humidity.On another note, do T5 tubes consume less electricity than flourescent?T5 is also a flourescent lamp(tube).T5 is more energy efficient than T8.for energy saving - look at their energy efficiency, the higher the better. Share this post Link to post Share on other sites
raincole 0 Report post Posted August 3, 2007 They say cannot change to electric ballast, comment that electric ballast will damage faster lor. Share this post Link to post Share on other sites
MaCe 3 Report post Posted August 3, 2007 They say cannot change to electric ballast, comment that electric ballast will damage faster lor.phlips and osram would have already closed shop if those comments were true.use google to search for electronic ballast + energy saving.Go to those light shops that has a in house electrician and not just plain salesmen who are more interested in closing deals. Share this post Link to post Share on other sites
raincole 0 Report post Posted August 3, 2007 But I did saw the ballast inside my light, it is under philips.Philips got electric and the normal ones is it? Share this post Link to post Share on other sites
