Jhlim
Laundry bracket with false ceiling?
Hi all... I have a false ceiling in the yard area.. Is it possible to still hang those traditional bamboo pole? Got such thing as reinforce the force ceiling until can hang laundry de mah? Trying to avoid installing laundry system for now.. thanks..
you need to install down rods which are mounted to the concrete ceiling and then install your laundry bracket to these rods. cannot install the brackets to the false ceiling as the plasterboard of false ceiling cannot take the weight of the laundry.
This is a very good post, gives users on how to install a laundry system and you are exactly right also when it comes to the false ceiling issue as well
