SnowAngel
Pls Advise On My Quotation...
Hi ppl,
This is the quotation i received from one of the company. Can help to advise me if this quotation is ok and reasonable, thank you very much! :D
Item 3-YEAR WORKMANSHIP WARRANTY Description Amount
PROFESSIONAL SERVICES
1. DESIGN CONSULTATION ,FURNITURE LAYOUT PLAN & MASTERIAL PROPOSAL FOC
2. 3D PERSPECTIVE DRAWING ,PROJECT CONSULTATION & MANAGEMENT FOC
3. ON SITE SUPERVISION BY QUALIFY PERSONNEL FOC
12
LIVING HALL AND 2 BEDROOMS
SUPPLY LABOUR TO LAY HOMOGENEOUS TILES WITH SKIRTING FOR LIVING HALL & 2 BEDROOMS(<$3PSF) $ 2,780
NOTE: SUPPLY/INSTALL LAMINATED FLOOR WITH SKIRTING FOR LIVING HALL & 2 BEDROOMS(INCLUDE HACK EXISTING SKIRTING =$2280
KITCHEN
1 SUPPLY/LAY CERAMIC/HOMOGENEOUS TILES FOR KITCHEN (<$3psf) $ 880
2 WATERPROOFING FOR KITCHEN TO BE CARRIED $ 200
3 SUPPLY/CONSTRUCT FULL HEIGHT WALL TILES FOR KITCHEN (<$3 PSF)EXCLUDE CABINET AREAS $ 2,280
4 CONSTRUCTION OF FRIDGE ,WASHING MACHINE AND CABINET BASES $ 390
5 RELOCATION OF INLET/OUTLET PIPING FOR SINK AND WASHING MACHINE $ 220
6 SUPPLY/INSTALL SOLID LAMINATED KITCHEN CABINET (BOTTOM=12FTS) $ 1,200
7 SUPPLY/INSTALL SOLID POSTFORM WORKTOP FOR KITCHEN CABINET $ 250
8 SUPPLY LABOUR TO INSTALL COOKER HOOD, HOB ,OVEN ,SINK & TAP $ 50
9 TO DISMANTLE AND DISPOSAL EXISTING KITCHEN CABINET $ 150
WHOLE HOUSE AND GENERAL
1 DEBRIS REMOVAL & HACKING OF FLOOR SCREED AND WALL SCREED $ 880
2 HAULAGE OF SAND SERVICE TO BE CARRIED OUT $ 650
3 SUPPLY/LAY CURROGATED BOARD TO PROTECT EXISTING/NEW FLOORING (INCLUDE DISPOSAL) $ 150
4 WHOLE HOUSE CHEMICAL WASHING AND CLEANING $ 200
NO GST,NETT TOTAL $ 10,280
12
KITCHEN
4 CONSTRUCTION OF FRIDGE ,WASHING MACHINE AND CABINET BASES $ 390 this one is on the high side. Usually about $70-80 each for the washer base and fridge base... works out to $230 for your cabinet base. How many feet of cabinets you getting? For my EA, 14 feet of cabinet base is <$200
5 RELOCATION OF INLET/OUTLET PIPING FOR SINK AND WASHING MACHINE $ 220 This one is also expensive. My contractor did mine for only $60 each
6 SUPPLY/INSTALL SOLID LAMINATED KITCHEN CABINET (BOTTOM=12FTS) $ 1,200 Are your cabinets bottom only? this price is a little above average... but ok if you can accept it.
7 SUPPLY/INSTALL SOLID POSTFORM WORKTOP FOR KITCHEN CABINET $ 250 post form require some maintenance... are you sure you want postform?
2 HAULAGE OF SAND SERVICE TO BE CARRIED OUT $ 650 this one is on the high side. Call your town council to ask how much is haulage for both the debri removal and the sand haulage to give you a guide.
4 WHOLE HOUSE CHEMICAL WASHING AND CLEANING $ 200 Some EAs are getting their chemical cleaning for <$150. no reason why a three room flat cost more.
Your renovation is super minimal based on your quotation. So the pricing is about there. Except for the few items I highlighted, your quote is quite okay.
what you need to find out is what brand of laminates are you getting for your cabinets?
what brand of homo tiles are you getting and what size? The larger tiles costs more to lay (eg 800x800)
Are you going to do a replacement of your water piping to copper or stainless steel?
How bout electrical works? Not doing any re-wiring or repositioning of your lighting points or socket points?
How bout painting works? Not going to paint your house?
do a search of the forum for other people's quotation to do a comparison with yours.
I have not touch any quotations for a long time... I may have missed out something that I did not ask in the above lists of questions.
Hope it helps :notti:
