wtg54
Not So New Sk Ea
Quotation
Wet Works - Flring like quite ex. Think my 130sq homo less than 10k. I didnt do toilet or wall tiles.
Plumbling Works - S/s piping is hot and cold or only cold? $780 maybe ok if hot/cold.
Painting & Ceilings Works
1 Plastering for whole house $1,800 => How old is the house? Y need plaster?
2 Painting for whole house using 3in1 ICI / Nippon paint $1,150 => Like ok, ask how many colours and wat paint.Aluminium Works
1 Supply & Install 2 nos of Aluminium Bi-fold door @ 2 Toilets $480 => Quite ok
2 Supply & Install 1 no of frameless temper glass shower screen @ 2 Toilets $560 => Quite ok
3 Supply & Install 1 no of frameless casement glass door ( partial sand blaster ) @ Kitchen Entrance $680 => Should be less than $600
Wooden Doors Works => Like quite ok
1 Supply & Install 3 nos of classic doors in paint finish @ 3 Bedrooms $540
2 Change existing main door lock set $180
Carpentry Works
1 Fabricate & Install 32ft top & Bottom Kitchen Cabinet @ Kitchen in laminate finish $3,200
Top: 16ft Bottom: 16ft => Ok
- Max ht for Kitchen range from 34'' to 35'' including soild top
2 Supply & Install 16ft soild surafce top on Kitchen Cabinet $1,280 => Wat brand? Cheapo brand ppl usually charge 70/pr
7 Fabricate & Install 16ft wardrobe @ Master Bedroom in laminate finish $4,000
- 6ft & 10ft => Sliding max 220, casement door about 200/fr
Hi thanks for the previous reply
Going to do homogenous tiles for my whole place including bedrooms.
do i need to overlay laminated wood? or it is all right to leave the tiles top at the bedrooms?
anyone any advice or comments?
my whole house is homogenous tiles including bedrooms
but why do you need to overlay laminated wood ?
Hi
i was just thinking cos i heard some comments that the floor will be too cold.. dun know how true it is...
so ur whole place with homogenous tiles and no overlay, any problem? is it too slippery? do u also have same homogenous tiles for your balcony?
Hi
maybe i need to rephrase my sentence :rolleyes:
my living room + bedrooms all homo tiles and my balcony, my kitchen and service balcony and toilets uses the diff kind of tiles not those glossy homo tiles
Homo tiles are not cold... they are just tiles. only natural kind of tiles like marble and granite will be cold during wet season...
homo tiles slippery if there's water on the floor and you did not walk with care.
i dun understand what you mean overlay ? you mean on top of the homo tiles overlay another lay of laminated wood etc ?
maybe i need to rephrase my sentence !!
Thanks for the fast reply.
I actually meant overlay laminated floor over the homogenous tiles. feel a waste but told will be more cosy looking with laminate floor..
u have problem maintaining the tiles then?
:rolleyes:
Tiles is the easiest to maintain !! cos they are not afraid of water like wood/laminated wood :rolleyes: one bucket of water + some floor detergent...and you can clean the whole house with easy :)
laminates are layed over cement screed and not homo or any other tiles, because a firm level base is required before the laminate wood can be layed.
UNLESS you intend to do a platform as cosy corner then you can lay the tiles 1st then build the platform over it ..... at least when you removed the platform, the tiles below the matches the surrounding tiles :seeya:
Tiles is the easiest to maintain :rolleyes: cos they are not afraid of water like wood/laminated wood :) one bucket of water + some floor detergent...and you can clean the whole house with easy :seeya:
UNLESS you intend to do a platform as cosy corner then you can lay the tiles 1st then build the platform over it ..... at least when you removed the platform, the tiles below the matches the surrounding tiles :(
thanks zeny
been helpful. how about toilet floor tiles? if i am changing, should i overlay better or hack off and redo?
thanks zeny
hmm.... overlay the toilet tile is cheaper than hack off and redo so it is petty much depend on your budget
but then overlay has it problem too. some people worried that the bottom tiles that is not properly layed may pop up one day and damage the overlayed tiles.
for me it is hacked and redo..complimentary from HDB :rolleyes:
Edited by zeny
for me it is hacked and redo..complimentary from HDB !!
envious envious
how did u get HDB to redo it for you? they do whole toilet or just floor or wall?
is it true they redo and the finishing not so good? so far any problem?
btw where ur unit?
envious envious
btw where ur unit?
too many hollow tiles ..so they got no choice but to redo all my kitchen and toilet wall tiles as well as toilet floor tiles !! the good thing is we top up a bit of $ and get to choose the design of the tiles we want and they lay it for us...so far so good...... :rolleyes:
which unit...let's just say we are Wtg's neighbour :)
Edited by zeny
oic
i also have some tiles defect. poor workmanship.
got more than 10 with cracks for my bathroom wall tiles.. sigh.. will HDB change piece by piece or redo the whole thing?
oic
that you got to check with HDB
for mine, there's more for each toilet that is why they hacked everything and redo
