Topline
Access from kitchen
Hi, i notice many houses have a back door in their kitchen. I intend to have an access to the back yard just in front of the kitchen where my dining area is. Im considering not having an access to the back inside the kitchen itself. Any thoughts about that? what would i miss out by not having this door inside the kitchen?
Well, it really depends on how you plan your usage. Backyard normally is used as a laundry and washing area. So if you have big kitchen utensils which can’t fit into the sink fo washing, you can bring it directly out through the kitchen to wash instead of having to go through your dinning area.
Also, if you have guest in the house and are seated at the dinning area, it’s not going to be very nice to bring laundry in/out through the dining area while your guests are around.
Go through the scenarios when you need to access the backyard and determine if you are ok to access it via the dining room or it it better through the kitchen
