OnePostWonder
Newbies @ Jalan Membina
postwonder
could you email me as well to fionacll@hotmail.com many thanks
how's your quote $$?
mine is 21k (includes bedhead,bed side table,shower screen on mbr,L-feature wall on bomb shelter and L-feature wall on dining area,shoe rack,window grilles). The rest are in the normal package(dining room tv console and feature wall,kitchen cabinet).
Mine is all homo tiles, but i dont have aircon and platform
hehe today going to select tiles
yup, not impressed by the way the ID pushed for sales...
Bro, u should be starting earlier than us right?
ya, agree that the ID is slightly agressive. My fiancee feel the same way also. But yesterday after we went to see a completed reno flat, was quite impressive with the work done. After much thoughts, as long as the worksmanship is good and price ok,we are ok also. Hope i dont regret..pray hard that everything goes smoothly
Hi post, can email me your quotation also to jasch@pacific.net.sg ? thanks! :(
Hi Yang Guo, Can you email me your quote also
thanks.
Edited by jasch
that's cheap... I was quoted 24k with platform, grills, parquet flooring but no bomb shelter feature wall
Sorry, the scanner refuses to work with Windows Vista...
PM me if you interested in my ID's contact
not an issue. thanks
can you email me your ID's contact? thanks
Hi all,
Sorry to side track a bit :( have anyone done a calculation on the cooling capacity on a 4 rooms of our flat?
MBR = How much capacity in BTU?
BR2 = How much capacity in BTU?
BR3 = How much capacity in BTU?
Living room = How much capacity in BTU?
Need to be looking ard for aircon now...!!
i am sending u all my non-revised quote. I havent got my revised quote yet (i have the hard copy but dont have the soft copy)
:P i got your quote (1st quote), thanks. seems within our budget lei.
OK. this is another quote with Ms.Lim frm Allbest.
Starmex - mitsubishi easy clean (4 check for environmental friendly and energy saving):
System 2-in-1 Inverter : S$2000
System 3-in-1 Inverter : S$2600
System 4-in-1 Inverter : S$3500
above is 3/8" insulator, WITH GST and with installation etc.
Non inverter one should be cheaper by 500-700 I think
personally I feel if 2 or more bedroom switch on the aircon most of the time, then it's better to have inverter.
for calculation.. hehe.. this really have to check with the expert.
Just to share some of the new things I learnt about aircon when I visited Best Tech on Sunday...
Who are those who should consider Inverters Aircon?
eg. For a single room, if you turn on the aircon for 8 hrs daily, you should consider an inverter. However, if you only require it for an hr or 2 daily, there should not be a need.
Difference in the way non-inverters and inverter aircon compressor work?
For non-inverter, typically has only 1 speed of operation, whereas inverters can work at different speeds.
Difference in the way the motor works?
For non-inverters, since it only goes on or off (no inbetween), more energy is used up whenever you need to start the motor from rest repeatedly. (ie. non-inverters always turns on/off inbetween usage, off when the desired temperature is attained.)
As for inverters, the motor will be in operation continuously. But based on the needs, it's speed may vary.
To explain how inverters save more energy, lets imagine if we are driving. Over a trip that takes 8hrs (regardless of distance), which would use up more fuel? One that has lots of traffic lights, where you have to continuously start and stop every few minutes? Or one where you just start off, and move at a continuous speed?
Hope this sharing is useful :P
For those who have completed renovation or in the midst of it, may I know if a system 4 compressor (Toshiba or Mit Starmex) can go out of the aircon ledge window?
Thanks.... :P
Hope this sharing is useful :jawdrop:
the economics aside, perhaps could consider the environmental impact and do our bit to save the earth :P ...
aircons use either the R410A or the R22 refrigerant... the R410A refrigerant does not attack our precious ozone layer whereas R22 refrigerant is an ozone-depleting substance...
most, but not all, inverters use R410A refrigerant... a few daikin inverters use R22 e.g. 4MKD75DVM...
most, but not all, non-inverters use R22 refrigerant... a few mitsubishi electric non-inverters use R410A e.g. MUX-4B26VB...
indeed, R410A aircons are more expensive than R22 aircons...
well, just to encourage everyone to consider the environmental impact together with the economics :bangwall:
yang guo, urs is 4 room? can forward ur quotation to me as well? thanks alot!
my email : davsu090308@gmail.com
wow, see that most has sign up with ID liao. I'll be going for contractor as simple renov, as already know what to do with the house.
am still sourcing around, hopefully it dun take too long.
