Woodlander
Pineapple Salt Rice?
I had just received my keys to my flat. However i heard from some friends that there are some ritual that need to be done when entering the house like throwing a pineapple and throwing salt mixed with rice into the house. Is this true? And should i do it before the renovation or after? I had went in to take a look already.
Pls kindly advise.
Thanks!
Pls kindly advise.
Thanks!
I just did mine yesterday.. When open door, throw a handful of rice/salt into the middle of your house.. then follow the left side of the wall (left wall when facing out the door) and continue throwing rice/salt at all the corners.. follow this wall into all rooms and corners... Once you reach the main door again, throw the remaining rice/salt outside your door.. And leave the house..... For the pineapple, think u can do it before everything and just roll into the centre of hall..
Just my 2cents worth... I read this from a fengshui book... Maybe the more senior forummers can help you more.. :thumbs up:
Pls kindly advise.
Thanks!
Hi .. it depends on yr religion .. if u r a buddhist, then do it the buddhist way if u r a taoist then do it the Taoist way ... there is no "fengshui" way ....
