LC LC
Korea Luxurious Designer Fire Rated Safe $1299(U.P.$1899) Nikawa Evolve Designer Safe EV040-SG
Features
A touch screen keypad that lights up upon touch. Can activate stealth mode for silent unlocking
User Pin –  2 user of 4-20 digits
Keypad lockdown for 3 minutes after 5 wrong pin entry. The alarm will also sound off.
Low Battery Indicator
Emergency power up using Micro 2.0 USB port
5 x Dia 19mm locking Bolt (3 live, 2 fixed)
Inbuilt with 120-decibel alarm that has a tilt sensor
Allow bolting to the base
Modern design without electronic front to blend into interior design and support camouflage
KS 1hr fire test
Support auto-lock function with motorized motor
Made in Korea
Technical Details
External dimension H x W x ? 536 x 410 x 475mm
Internal dimension H x W x ? 412 x 305 x 320mm
Net Weight (kg): 63
Volume (litres): 37
Internal shelf: 1
19mm steel locking bolts
Use 4 x AA (1.5V R06)
PM or WhatsApp 81860696 to order/enquire
Fast Delivery!!!!
