Looking for the best mattress for back pain? This guide will help you select a mattress that will help alleviate your back pain without creating other problems. Often people find a mattress that addresses lower or upper back pain only to find that they then get shoulder soreness. Below are some mattresses that should make your bed a more welcoming and relaxing place. While the right mattress will go a long way to alleviating back pain, it’s not a silver bullet. There are other health factors to consider that go beyond the limits of a good mattress. Keeping a healthy weight and stretching your body so that you are in alignment before getting to bed will help dramatically.
This guide provides useful tips on how to optimize your bedroom for the best sleeping experience with the least amount of pain.
What Causes Back Pain while Sleeping?
Back pain is caused by your spine being out of alignment while you sleep. No matter what your sleep position your are vulnerable to back pain.
According to Web MD, 80 percent of the population experiences some form of lower back pain at some time in thier lives. This is also known as nocturnal back pain.
There are 3 major causes of back pain that could be contributing to poor sleep at night.
  1. Mechanical problems with the spine, the most common of which is disc degenerations. Discs act like a shock absorber between your vertebrae and can break down with age.
  2.  Injuries such as a fall or car accident can sprain or fracture your spine causing your discomfort.
  3. A disease such as scoliosis or spinal stenosis which is a narrowing of the spinal column can lead to back pain. Even kidney stones, pregnancy or arthritis could cause lower back pain.
Despite these common causes, sometimes the cause of your back pain cannot be determined.
Best Stretched for Back Pain Before Bed
Before you even get into bed you should work on loosening your muscles and get into alignment. Because our lives are mostly sedentary we are usually contorting our bodies in unnatural positions as we sit at our desks. When it comes time to lay down, our body needs to adust. Stretching out before you go to sleep will allow you to get the full benefit from your mattress.
Check out these recommendations from Seasoned that you can do before bed. While you may not have time to do them every night, try and get some stretches in at least 3 nights a week and start reaping the benefits of better flexibility and longer and more productive sleep.
Back Pain and Side Sleepers
back pain for side sleepers
Back pain for side sleepers can best be addressed in 2 ways. First, make sure you have a pillow that is giving you proper support. This goes for all types of sleepers but is especially applicable to side sleepers. I have noticed that most side sleepers sleep on pillows that do not have enough loft. This means their neck is out of alignment causing other issues.
Secondly, make sure that the middle of the mattress is giving your hips proper support. Check out this nice diagram from the Cleveland Clinic that illustrates this point.
I have found that side sleepers need to pay extra attention to spinal alignment.
In the picture below you can see that this sleeper is using a body pillow to keep from falling forward and her knees separated this keeps her from moving onto her stomach and with alignment.
Spinal Alignment Sleeping
Back and stomach sleepers should look for firmer mattresses that don’t allow their lower back to sink too much. Conversely, if you have upper back problems it could be that your mattress is too firm. It’s a delicate balance so you need to listen to your body.
There are now new coil systems on the market that can be found in many of the online brands that ensure you are getting optimal support around your hips. The quantum coil system from Legget and Platt is a perfect example. It is a zoned coils system that has firmer coils in the middle of the mattress and softer coils on the top and bottom that help balance you out over the entire mattress.
The Brentwood Home Oceano mattress has this system and is one of my top picks for side sleepers with back pain because it is still a relatively soft mattress but also offers great support where it needs to. This is probably your best bet overall if you want quality, craftsmansip, value and comfort all in one.
Best Mattresses 2016 from The Sleep Sherpa 9
How to Shop for A Mattress for Back Pain
Usually, every new mattress is going to feel better than your existing mattress. Chances are your existing mattress has worn down from years of use. I find that mattresses now start to break down after 7 years. Anything beyond that seems like bonus time.
If you are searching online for a mattress or heading out to the mattress store, make sure that you understand a bit about construction. In my opinion, a dense memory foam mattress is one of the best types of mattresses to alleviate back pain. That’s because they conform so well to your body that there isn’t any part that is not supported.
If you prefer a spring mattress, ask if the coil system is zoned. A zoned coil system will offer more support near your hips and lower back and allow your shoulders to sink towards the top of the mattress to keep you in alignment.
While shopping in stores, take your time. There’s no pressure to buy right away. The longer you lay on the mattress the better sense you will have of how it feels in your home during the night. I also advise people to shop when they aren’t too tired. If you shop for a mattress after a long day, just about anything will feel great and it will be harder to distinguish between mattresses.
Don’t Forget Your Pillow
While mattresses bear the majority of the blame for back pain, pillows play a part too. Often people sleep on pillows with the wrong amount of loft. If you have broad shoulders and sleep on your side, you need a pillow with a lot of loft so that your head won’t sink to far down. An adequately sized pillow will also prevent you from wanting to sleep with your arm under the pillow which causes shoulder pain.
Stomach sleepers need a thinner pillow. A thick pillow for a stomach sleeper often leads to lower back pain. The same is true for back sleepers although they can get by with a bit more loft, especially if they snore.
Below are my top picks for best mattress for back pain…
Best Memory Foam Mattress for Back Pain
Nectar Mattress
Nectar Mattress for Back Pain
The Nectar mattress is a dense memory foam mattress that really cradles you in every position. I highly recommend this to sleepers with lower back pain. No matter what position you sleep, the Nectar will conform and support you. It is also a very affordable mattress with a great 365 night free trial period.
Get the Full Nectar Mattress Review
Best Spring Mattress for Back Pain
Winkbeds
winkbeds for back pain
The Winkbed skews a little firmer than most online mattresses but it gives you great support along your lower back. If you have upper back pain as well, I recommend going with the soft version over the luxury firm. This mattress sleeps cool as it is primarily a spring mattress with a Tencel cover.
Get the Full Winkbeds Review
Best Performance Mattress for Back Pain
Layla Hybrid
layla hybrid
The Layla Hybrid is a flippable mattress with a firm and soft side. It incorporates next generations foams that are cooler and more responsive along with a quality spring system for superior support. Even sleeping on the soft side, you will still feel supported along our lower back while getting excellent pressure relief. Chances are this mattress will be your favorite.
Read the Full Layla Hybrid Review
Best Natural Mattress for Back Pain
Avocado
Avocado Mattress
No other mattress that I know of has received more certifications and awards in the natural mattress category than the Avocado. It is truly in a class all its own. The quality of materials and craftsmanship is on a level all its own.  In regards to back pain, they have two options, the regular and pillow-top option. The Avocado is a firmer mattress so go with the pillow top if you want to get good pressure relief.
Read the full Avocado Mattress Review
With all of the mattresses listed above, you get a generous trial period, so if by chance they don’t address your back pain properly, definitely return them and try another. Eventually, you will land on the right mattress to get you back to a sound sleep and refreshed mornings.
By age, I understand how much is important to have a good mattress to keep your spine healthy. Many works at offices and that types of lifestyles is not best. Found this guidance to best sheets possible also made from bamboo. This Review of Bamboo Sheets has direct link to Amazon. To sleep in comfort is one of best privileges and cures after long day. Very often after work I really want to see my bed and that’s it. Give a lot of pleasures when sheets are fresh and if they are made so good like the one on the link, you can lose your job, if you know what I mean.
Yeah, by ageing I feel like a good mattress can really be your good friend, even if we talk about your mood in the mornings. But from a different angle, there are so many other pain killing friends. One of the worst so far is alcohol, I think. Yeah, you can fall asleep even on the stairs and feeling like you are sleeping on some soft sheep wool, but by the morning your back will have something to say to you. The story with kratom is completely different. If you want to understand what I’m talking about just try here kratomgallery.com. They will definitely satisfy your demands! Wish you a very comfortable sleep, man.
Edited by Brandcalfe
Hello everyone, when I was looking for a mattress for my bedroom, I really wanted this mattress to be of high quality and serve me a large amount of time. Therefore, I turned to Saatva Luxury Firm, because they produce the best mattresses there. I really liked the mattress that I received and indeed it is very comfortable and also very high quality. Therefore, if you are looking for a mattress for your bedroom, this is the best option you can find.
