sleepsherpa
Do Weighted Sheets Help Keep Bedding in Place?
What’s worse than making the bed? Keeping the sheets and covers in place the whole day. For those who hate making the bed, having to put the sheets and covers back in their proper place several times throughout the day can be quite a chore. Unfortunately, bedding tends to get all tangled or end up in a mess on the floor. Not only does this look unpleasant but also makes for additional work when making the bed. Even those who do not dislike making the bed can get frustrated if the sheets and blankets keep tumbling down to the floor throughout the day and during the night. Keeping the bedding in place is the key to a tidy bed. Even if the sheets and blankets do not slip off on their own, several people are in the habit of kicking off the sheets and covers during the night. When bedding comes into contact with the floor, it gets dirty and requires more frequent washing.
Weighted Blanket to Prevent Slipping
There are a few ways to prevent bedding from slipping off the bed without spending a fortune. One of the most popular ways to achieve this is by using weighted sheets. In recent years, weighted sheets have become known for the ability to alleviate symptoms of insomnia and anxiety and aid in more restful sleep. But heavy sheets and blankets have long been used for preventing the bedding from slipping off. To achieve this, you need a blanket or top sheet that’s heavier than the rest of the bedding. The heavy weight of the blanket or sheet helps keep the bedding from slipping off.
What we now know as a weighted blanket is actually a sensory blanket filled with plastic pellets used for insomnia, anxiety, and autism. These blankets are expensive than regular blankets. But for keeping your bedding in place you do not need these sensory blankets sensory blankets. A regular blanket that is significantly heavier than the rest of the bedding can work just as well in keeping the rest of the sheets in place.
Choose the Right Materials
Regardless of the type of top sheet or blanket that you choose, special attention should be paid to the materials. There are a lot of people who are fond of the silky, luxurious bedding materials, such as satin and silk. In places like hotels and resorts, these silky materials are found all over, because they are supposed to lend a stylish and luxurious touch to the bedroom. People often use these materials for their regular bedroom decor.
There is no doubt that silk and satin are more stylish and attractive than fabrics like cotton or wool. But unfortunately, these silky materials are also notorious for sliding off the bed. Instead, choose cotton, linen or flannel sheets, duvet covers, and quilts, avoiding any fabric that is shiny and silky to touch. When cotton, flannel, and linen are washed regularly, they keep becoming softer but not slippery. If you want to give a luxurious finish to your bed, you can choose fabrics like cashmere or chenille. These fabrics are often used to make chunky blankets that can also be used as a top sheet or a throw. These fabrics offer the softness of satin or silk while the chunky knit adds weight and keeps them in place.
If you still prefer satin or silk sheets and blankets, choose a fitted flannel sheet on top. The friction that is created between the silky sheets and the flannel top sheet keeps the bedding in place.
Keep It Tucked In
Another easy and effortless way to keep bedding from slipping off is to tuck the edges of the sheets or blanket underneath the mattress or the box spring. Sheets or blankets that are secure are less likely to slide off or move around and also require less time and work to make the bed in the morning.  Regardless of whether the sheet is heavy or light, keeping it tucked under the side of the mattress can prevent it from moving even when you toss and turn in bed.
Use Bedding Straps/Suspenders
Keeping bedding secure is a foolproof way to prevent sheets and blankets from sliding off. This can be done by using bedding straps or suspenders. Straps or suspenders provide bedding with an additional layer of security. Once the sheets and blankets have been tucked into place, the mattress should be lifted at the corner at the foot of the bed and clipped to the suspenders crosswise along each corner.
If you clip them crosswise or diagonally, the blankets remain tucked without having to run an entire suspender along the foot of the bed. If you buy high-quality bedding straps, they are capable of attaching to more than one layer and can be used to hold together the sheets, blanket, and quilt at the same time. This not only removes unnecessary bulk at the foot of the bed but also provides a neat, hassle-free solution to keeping the bedding in place.
Make the Bed
The unfortunate truth is that even the best-made bed becomes messy by the end of the night. Therefore, you cannot expect your well-made bed to last forever and stop making your bed every morning. More often than not, sheets and blankets tend to slide off a bed that’s disheveled. To make your bed the right way, first spread the sheets and then tuck the edges underneath the mattress, folding the corners over and tucking them along the sides. This process should be repeated with the blankets. The heavier items should be placed on top of them to keep the layers from sliding off. Don’t forget to tuck the edges and use straps to keep the layers together.
While weighted or heavy blankets do keep the bedding in place, they aren’t the only solution. Using the right fabrics, clipping the layers together, and making the bed the right way every morning are also equally effective in keeping the bedding from sliding off the bed.
