caitlin99 0 Report post Posted February 22, 2020 1. Select the profile according to joint width, to ensure proper support of the lateral crosspiece. 2. The joint cavity must be at least 3/8" (9 mm) deep and free of debris. Substances that inhibit adhesion must be removed from the sides of the joint. 3. Fill the joint with elastomeric sealant such as Schluter®-KERDI-FIX or similar. Then insert the vertical leg of RENO-T in the joint so that the lateral crosspiece rests completely on the edges of the surface coverings. Share this post Link to post Share on other sites
