raincole
Door Facing Balcony
sit north face south?
make sure hor, if you got the degree wrong then you will be trouble should you seek for advices.
try to post your bearing here, eg how degrees south.
as for cabinets to block...you can consider ikea's BILLY range.
cos BILLY range can extend the height all the way to ceiling.
good for blocking the balcony from main door, if your main door is 1.2m, block 1.2m or a little more at the balcony.
this is the pic you take while standing at the main door??? :(
altar how come faces another direction???
get those chinese partition to block off the windows.
i only glance .. didn't notice abt the altar is there. Hahahaaaaaaa
i do hope i am wrong, that the pic was taken NOT at the main door.... :(
the big problem with DANGKEE + conman FSM is that they like to assume the main flow of QI comes thru the window. Which is total NONSENSE, unless the family who stays in the house uses the window to enter/leave the house.
most of the time, they are using the 采光 method.
but main flow of Qi is another thing...
altar should face main door and only in very special structured houses where by there is really no place to put the altar, then the window is the second choice.
actually is it enough to bring floorplan down to the FSM for consultation?
coz my unit is NS facing and i just want to know the don't, not so much the wealth spots or what-nots
APPLEFREAK:
refer to this
north
壬——337.5 deg to 352.5 deg
子——352.5 deg to 7.5 deg
癸——7.5 deg to 22.5 deg
south
丙——157.5 deg to 172.5 deg
午——172.5 deg to 187.5 deg
丁——187.5 deg to 202.5 deg
Why can't sleep beside the kitchen? My main bedroom is beside kitchen.
My headache is that the door is facing the balcony with the kitchen beside the balcony.
I don't know how to upload pic, must be a link??
sleeping beside kitchen is the last choice - cos too much FIRE!
nothing wrong with kitchen besides balcony.
should you able to see the opposite block thru the balcony while standing at the main door. Then you need to reate a partition to block it. Or get cabinets to block it.
hahahaha
APPLEFREAK:
refer to this
north
south
agree for those normal altar position.
Btw.. u give him that degree .. does he know how to use a compass to stay in the mid-point to take direction ?
hahahaha
dunno how to :bangwall:
my floor plan below, possible to help or not???
MBR window is facing dead west
hahahaha
i already warned. if he/she assumes it's XXX degrees and ask for advice, she gonna get advices based on that XXX degrees. And should the house is actually a different degree then cannot blame others liao.
applefreak -
you need to block off 1/3 of the balcony.
this has got nothing to do with your house facing.
Assuming the direction is correct.
Means the Door is located at South .. or SOuth East. sector.
applefreak -
Bro Mace .. actually no need to block 1/3 because that window at Balcony wall is not FUll HEIGHT.
need to prevent the Qi from going out thru..
size of cabinet need to be slightly bigger than the main door's width n height.
Qi ... actually as long as it is around our wrist area can liao ... did you saw mine ?
remember when you insists that your teacher told you hanging a windchime will gather ghosts?
and then a couple of days ago you post something totally different????
vomit blood.
http://www.renotalk.com/forum/index.php?showtopic=7297
Edited by MaCe
Guest
This topic is now closed to further replies.
