s&s
Water Festure Placement
Hi Mr Chong,
I intend to purchase a water feature and I understand that it is a fengshui item.
As such, I will like to know where is the best place to place it?
I thought of placing it near the foyer of the main door entrance.
Hi Mr Chong,
Hello s&s
Pls put up your floor plan and compass direction. Read sticky pls.
Hello s&s
Hi Mr Chong,
sorry, heres the plan:
Hi Mr Chong,
Hello s&s
I assume the red dot is your intended placement.
If the living room is where you want to place, then I suggest that you place it at the wall of Kitchen adjoining the bomb shelter. (Hope I read the print correctly). Or you can place at the right corner of the balcony next to your study.
Hello s&s
Thanks Mr Chong, for your advice.
Originally I thought of placing it at the foyer as indicated by the red dot.
Thanks anyway.
The Buddha says
"To overcome miserliness and develop generosity. Generosity is a cause of wealth. To think that practicing generosity is only for one's own benefit is a very limited thought. Like other practices, the best and most powerful motivation is to think of benefiting all beings."
Hello s&s
Is there a reason for the chosen location? I read that putting a rat & dragon figurine is also to enhance the water formation? Can explain further? Thanks.
Basically S&S only gave a very general direction of the house. The north and SE area of the living room would be one safe way to put.
Putting figurines is not my practise, therefore can't comment much.
Normally when comes to placement of water, it is better to investigate the house properly before doing so. Otherwise may risk getting the bad.
