Goingbonkers 0 Report post Posted December 30, 2018 Hi, I am so lack of knowledge in this area. Anyone knows if it is possible to change the configuration of current kitchen cabinets without dismantling it ? For example, I have 2 drawers Medium size I want to remove them and also remove 1 skinny cabinet door which is next to the drawers. Then remove the divider between the drawers and skinny compartment and then replace the whole compartment with wider drawers. So basically I want to re-divide the inner space without dismantling. Possible? Share this post Link to post Share on other sites
Nikz 0 Report post Posted December 31, 2018 Maybe? You can contact my contractor he got lobang for custom and affordable too try ask lah whatsapp everything also i ask him he sure got good price lobang 93910773 Share this post Link to post Share on other sites
Meifenn 0 Report post Posted January 3, 2019 Hello im a contractor here. Possible to send me some photos of the cabinets? Feel free to contact me at 8332 9514 for a non obligatory quote. Share this post Link to post Share on other sites
dnc specialist 0 Report post Posted January 11, 2019 (edited) On 12/30/2018 at 5:29 PM, Goingbonkers said: Hi, I am so lack of knowledge in this area. Anyone knows if it is possible to change the configuration of current kitchen cabinets without dismantling it ? For example, I have 2 drawers Medium size I want to remove them and also remove 1 skinny cabinet door which is next to the drawers. Then remove the divider between the drawers and skinny compartment and then replace the whole compartment with wider drawers. So basically I want to re-divide the inner space without dismantling. Possible? Nothing is impossible. It can be done but the work is going to be very complex. Changing a medium size to wider drawers cannot be modify. You need to make a new drawers as per your requirement which I think would be quite costly due to high labours cost in Singapore. Edited January 11, 2019 by dnc specialist Share this post Link to post Share on other sites
Lydia18 2 Report post Posted January 16, 2019 Finding a carpenter to help you modify or make new cabinets can be expensive in Singapore. Find out here and here as to where and how you can find a good carpenter respectively. Share this post Link to post Share on other sites
GarryGrey 0 Report post Posted December 6, 2023 I've been thinking about renovating my kitchen for a long time. The kitchen furniture was left over from the previous owner of the apartment and must be said to be very outdated. I'd like to find something new, including looking for an inexpensive but durable material for the tabletop and countertop. Share this post Link to post Share on other sites
GianCann 0 Report post Posted December 6, 2023 What do you think about artificial stone? For some reason, many people are skeptical about acrylic stone, although in fact it is a more than strong, wear-resistant and durable material that is excellent for a work surface. I liked options Corian Kitchen Worktops in Total tops, so I advise you to pay attention to this option. Share this post Link to post Share on other sites
shaunling 5 Report post Posted August 6 Yes, it is possible to modify your current kitchen cabinets without dismantling them. You can remove the drawers and the skinny cabinet door, along with the divider, and replace them with wider drawers. This process requires precise carpentry work but is doable. I recommend consulting with a skilled carpenter who can assess your cabinets and provide a custom solution. Share this post Link to post Share on other sites
