JamesOchoa 0 Report post Posted October 26, 2018 (edited) So I am moving my drain a few inches to accommodate my new shower. The current PVC setup does not allow a cut anywhere so I had to attempt to remove a glued insert that was in one of the joints. I used a drill out tool from a local hardware store. Now when I insert the new PVC connection it is slightly loose around edges but seems to be right where it touches the inside furthest point. Can I use Teflon tape so tighter fit along with primer/solvent? Should I be concerned about attaching with the normal procedure using cement? Is there something else I could try? or should I call plumbing services from Toronto to help me with this? Edited October 26, 2018 by JamesOchoa Share this post Link to post Share on other sites
