white_affair
Brick Outlines On Walls
Hi guys, I bought a RP flat from HDB and all the walls have the slight outline of the original bricks... Some areas even have big dents and are very uneven.. I just wana check with those who have also purchased RP flats if HDB did do anything about it?
I heard from one forummer that HDB actually did re-plaster all the units in her block.. I did submit together with my other defect but the HDB officer said cannot do anything about it.. :sport-smiley-003: I want to try again as I have taken more photos of the big dents..If not, I will have to spend alot of money just to re-plaster the whole unit.. Any advice?? :(
You'll likely have to spend your own money, unless it's near GE.
Property is normally bought and sold on an as-is where-is basis, especially for resale property. Hence, you have to live with whatever defects came with the flat.
I heard from one forummer that HDB actually did re-plaster all the units in her block.. I did submit together with my other defect but the HDB officer said cannot do anything about it.. :dancingqueen: I want to try again as I have taken more photos of the big dents..If not, I will have to spend alot of money just to re-plaster the whole unit.. Any advice?? :yamseng:
