Tumble 0 Report post Posted April 2, 2007 Dear all,We will be doing our reno for the first time and appreciate any advice on the quote below... Thanks!! Demolition works 1. Hack & remove whole house unwanted build-in furniture $800.00 2. Hack & remove 02 bathrooms wall tiles, floor tiles & all fixtures $600.00 3. Hack partial wall @ master bathroom to create vanity area $100.00 4. Haulage loading of sand, cement & material to unit $500.00 Masonary Works 1. Construct 63 mm hollow block wall @ master bathroom $480.00 2. Supply & lay heavy duty ceramic wall tiles with mosaic @ common bathroom $1,900.00 3. Supply & lay heavy duty ceramic floor tiles with cement screeding & waterproofing @ common bathroom $550.00 4. Supply & lay heavy duty ceramic wall tiles with mosaic @ master bathroom $1,900.00 5. Supply & lay heavy duty ceramic floor tiles with cement screeding & waterproofing @ master bathroom $550.00 6. Hack & repair damage timber strip flooring @ master bedroom (include repair damage skirting) $680.00 7. Supply labour & material to gain & varnish 03 bedrooms parquet strip flooring $800.00 Plumbing Works 1. Change whole unit cold water piping to stainless steel pipes $500.00 2. Change whole unit hot water piping to stainless steel pipes (4 hotwater points) $320.00 3. Connect inlet & outlet piping for 02nos of basin FOC 4. Connect inlet & outlet piping for kitchen sinks & washing machine FOC 5. Supply labour to install 02 nos of basin & pedestal WC $400.00 6. Supply labour to install 01 no of central heater FOC 7. Supply labour to install accessories @ both bathrooms FOC Ceiling Work 1. Supply & install light box @ bedroom 02 $360.00 Painting Works 1. Supply & apply 03 coats of ICI / Nippon pentalite paints to walls, ceilings (max. 8 colors) $1,100.00 2. Supply & apply ICI gloss paint to all water piping, gates, doors, door frames & sewage pipes $300.00 Box-up piping work 1. Supply & construct cement board box up sewage piping @ both bathrooms $400.00 Glass works 1. Supply & install 03 panels sliding door shower screen with tempered glass @ common bathroom $560.00 2. Supply & install slim line tempered glass shower screen @ master bathroom $680.00 Miscellaneous 1. Supply & lay protection sheet before starting of renovation work FOC 2. Cleaning up whole unit with chemical $200.00 3. Clearing off debris on site FOC Custom Made build-in furnitures 1. Supply labour to varnish exisiting foyer shoe's cabinet & change exisiting seater cushion fabric $520.00 2. Design & fabricate feature wall cum bathroom entrance door @ master bedroom (max 3500mm L) $2,400.00 3. Design & fabricate dressing console @ master bedroom (max 900mm L) $880.00 4. Design & fabricate headboard panelling design with 02 nos of bedside console @ master bedroom (max 3000mm L) $2,800.00 5. Design & fabricate 02 panel wooden door @ common bathroom $580.00 6. Design & fabricate vanity cabinet with build-in mirror & solid surface top @ master bathroom (max 1200mm L) $1,400.00 7. Design & fabricate vanity cabinet with build-in mirror & solid surface top @ common bathroom $1,050.00 8. Supply & change existing wardrobe door panels @ bedroom 03 $850.00 Total $24160.00 Share this post Link to post Share on other sites
Devilaz 0 Report post Posted April 3, 2007 Dear all,We will be doing our reno for the first time and appreciate any advice on the quote below... Thanks!! Demolition works 1. Hack & remove whole house unwanted build-in furniture $800.00 2. Hack & remove 02 bathrooms wall tiles, floor tiles & all fixtures $600.00 3. Hack partial wall @ master bathroom to create vanity area $100.00 4. Haulage loading of sand, cement & material to unit $500.00 Masonary Works 1. Construct 63 mm hollow block wall @ master bathroom $480.00 2. Supply & lay heavy duty ceramic wall tiles with mosaic @ common bathroom $1,900.00 3. Supply & lay heavy duty ceramic floor tiles with cement screeding & waterproofing @ common bathroom $550.00 4. Supply & lay heavy duty ceramic wall tiles with mosaic @ master bathroom $1,900.00 5. Supply & lay heavy duty ceramic floor tiles with cement screeding & waterproofing @ master bathroom $550.00 6. Hack & repair damage timber strip flooring @ master bedroom (include repair damage skirting) $680.00 7. Supply labour & material to gain & varnish 03 bedrooms parquet strip flooring $800.00 What are the range of tiles you are able to choose from?What is the dimension of each tiles?How much does it cost psf?Plumbing Works 1. Change whole unit cold water piping to stainless steel pipes $500.00 2. Change whole unit hot water piping to stainless steel pipes (4 hotwater points) $320.00For the pipings it is expensive. And it should be combined together not to spilt into 2 different things. 3. Connect inlet & outlet piping for 02nos of basin FOC 4. Connect inlet & outlet piping for kitchen sinks & washing machine FOC 5. Supply labour to install 02 nos of basin & pedestal WC $400.00 6. Supply labour to install 01 no of central heater FOC 7. Supply labour to install accessories @ both bathrooms FOC Ceiling Work 1. Supply & install light box @ bedroom 02 $360.00 Painting Works 1. Supply & apply 03 coats of ICI / Nippon pentalite paints to walls, ceilings (max. 8 colors) $1,100.00 2. Supply & apply ICI gloss paint to all water piping, gates, doors, door frames & sewage pipes $300.00 For paintings:1) Does ur max color include white or exclude?2) What are the range of paints can u used besides pentalite?3) If i want to choose other range of paints how much extra cost required? Box-up piping work 1. Supply & construct cement board box up sewage piping @ both bathrooms $400.00 Glass works 1. Supply & install 03 panels sliding door shower screen with tempered glass @ common bathroom $560.00 2. Supply & install slim line tempered glass shower screen @ master bathroom $680.00 What will be the thickness of the shower screen and the slim line shower screen? 10mm/5mm or lesser?Miscellaneous 1. Supply & lay protection sheet before starting of renovation work FOC 2. Cleaning up whole unit with chemical $200.00 Chemical wash for onces or twice?3. Clearing off debris on site FOC Custom Made build-in furnitures 1. Supply labour to varnish exisiting foyer shoe's cabinet & change exisiting seater cushion fabric $520.00 2. Design & fabricate feature wall cum bathroom entrance door @ master bedroom (max 3500mm L) $2,400.00 What material u are getting for ur feature wall?3. Design & fabricate dressing console @ master bedroom (max 900mm L) $880.00 What material u are getting?What is the brand of laminate they can give?4. Design & fabricate headboard panelling design with 02 nos of bedside console @ master bedroom (max 3000mm L) $2,800.00 What material u are getting?What is the brand of laminate they can give?5. Design & fabricate 02 panel wooden door @ common bathroom $580.00 Wooden door @ common bathroom? hmmm... waterproof?6. Design & fabricate vanity cabinet with build-in mirror & solid surface top @ master bathroom (max 1200mm L) $1,400.00 What material u are getting for soild surface top and vanity cabinet?What is the brand of laminate they can give?Got drawers?Mirror full height?7. Design & fabricate vanity cabinet with build-in mirror & solid surface top @ common bathroom $1,050.00 What material u are getting for soild surface top and vanity cabinet?What is the brand of laminate they can give?Got drawers?Mirror full height?8. Supply & change existing wardrobe door panels @ bedroom 03 $850.00 From wooden panels to frosted or? Total $24160.00Hope it helps. But the quote here seems a bit exp on it. It will be good to souce for more quotes and visit their site to see their workmanship. Share this post Link to post Share on other sites
Tumble 0 Report post Posted April 3, 2007 Hope it helps. But the quote here seems a bit exp on it. It will be good to souce for more quotes and visit their site to see their workmanship.Hi DevilazThank so much for ur reply... Pai-sei to say.. but for most of ur Qns below we dunno... We din ask the ID coz even if he did tell us, we won't know the diff... Below are a few which we can rmbr..how much does it cost psf?The ID mention something like up to $3.20... but dunno is it per tile or psf.. mosaic @ $11 What material u are getting for soild surface top and vanity cabinet?ID mention that it will be black granite for solid surface & veneer for cabinet.. (if i rmbr correctly..)Got drawers?No drawers.. but with doors & shelves.Mirror full height?Mirror will be wall to wall @ the basin area.. same length as the vanity cabinet.. I also tot the price is on the high side given the fact that we are just doing up 2 bathrooms & the masterroom.. The others are mostly hacking of unwanted fixture in the remaining 2 bedrooms and simply to add on a piece of board to mount our plasma... (we will be using the previous owner TV console.. )Will check again and may need ur help again with the quote when we finalised on it.. Once again.. tks!! !! Share this post Link to post Share on other sites
weireno 0 Report post Posted April 7, 2007 Dear all,We will be doing our reno for the first time and appreciate any advice on the quote below... Thanks!! TH Comment: The price quoted is a bit high on some place, reasonable on another place of works. neutral for some. So these is the usual trick used by contractor to quote you. Overall package seems .....I cannot comment on forum directly on price. However if you wish, you can contact the contractor who did my house, it provides trustworthy price and good workmanship. Lawrence hp: 92962735Demolition works 1. Hack & remove whole house unwanted build-in furniture $800.00 2. Hack & remove 02 bathrooms wall tiles, floor tiles & all fixtures $600.00 3. Hack partial wall @ master bathroom to create vanity area $100.00 4. Haulage loading of sand, cement & material to unit $500.00 Masonary Works 1. Construct 63 mm hollow block wall @ master bathroom $480.00TH Comment: It is 63cm about 0.6 height wall. Usually there is no guiding price for wall construction. It is really depends on relationship with your contractor or ID. Also depends on your whole dollars spent on them. 2. Supply & lay heavy duty ceramic wall tiles with mosaic @ common bathroom $1,900.00 3. Supply & lay heavy duty ceramic floor tiles with cement screeding & waterproofing @ common bathroom $550.00 4. Supply & lay heavy duty ceramic wall tiles with mosaic @ master bathroom $1,900.00 5. Supply & lay heavy duty ceramic floor tiles with cement screeding & waterproofing @ master bathroom $550.00 TH Comment: item 2 to 5 basically is renovating toilet. There is no useful fine details given to judge your price. e.g what is dollar value of ceramic tiles given to you? Is wall tiles till ceiling height? Overlay or hack-redo? What is your toilet wall surface sqf? also floor area sqf?6. Hack & repair damage timber strip flooring @ master bedroom (include repair damage skirting) $680.00 7. Supply labour & material to gain & varnish 03 bedrooms parquet strip flooring $800.00 TH Comment: Usually there is no guiding price for wall construction. It is really depends on relationship with your contractor or ID. Also depends on your whole dollars spent on them. . Plumbing Works 1. Change whole unit cold water piping to stainless steel pipes $500.00 2. Change whole unit hot water piping to stainless steel pipes (4 hotwater points) $320.00 3. Connect inlet & outlet piping for 02nos of basin FOC 4. Connect inlet & outlet piping for kitchen sinks & washing machine FOC 5. Supply labour to install 02 nos of basin & pedestal WC $400.00 6. Supply labour to install 01 no of central heater FOC 7. Supply labour to install accessories @ both bathrooms FOC Ceiling Work 1. Supply & install light box @ bedroom 02 $360.00 Painting Works 1. Supply & apply 03 coats of ICI / Nippon pentalite paints to walls, ceilings (max. 8 colors) $1,100.00 2. Supply & apply ICI gloss paint to all water piping, gates, doors, door frames & sewage pipes $300.00 Box-up piping work 1. Supply & construct cement board box up sewage piping @ both bathrooms $400.00 Glass works 1. Supply & install 03 panels sliding door shower screen with tempered glass @ common bathroom $560.00 2. Supply & install slim line tempered glass shower screen @ master bathroom $680.00 Miscellaneous 1. Supply & lay protection sheet before starting of renovation work FOC 2. Cleaning up whole unit with chemical $200.00 3. Clearing off debris on site FOC Custom Made build-in furnitures 1. Supply labour to varnish exisiting foyer shoe's cabinet & change exisiting seater cushion fabric $520.00 2. Design & fabricate feature wall cum bathroom entrance door @ master bedroom (max 3500mm L) $2,400.00 3. Design & fabricate dressing console @ master bedroom (max 900mm L) $880.00 4. Design & fabricate headboard panelling design with 02 nos of bedside console @ master bedroom (max 3000mm L) $2,800.00 5. Design & fabricate 02 panel wooden door @ common bathroom $580.00 6. Design & fabricate vanity cabinet with build-in mirror & solid surface top @ master bathroom (max 1200mm L) $1,400.00 7. Design & fabricate vanity cabinet with build-in mirror & solid surface top @ common bathroom $1,050.00 8. Supply & change existing wardrobe door panels @ bedroom 03 $850.00 Total $24160.00 Share this post Link to post Share on other sites
