Han Wei Aw 0 Report post Posted August 12, 2017 Hi everyone, Does the laying of vinyl flooring comes before or after carpentry installation? My ID mentioned they will install the built-in carpentry first, after which they will lay the vinyl tiles to prevent any damages to the vinyl tiles. Which means there will be no vinyl flooring underneath the built-in carpentry. My ID will return back the remaining unused vinyl as spare. Is this a normal practice? Please advise. Thank you. Share this post Link to post Share on other sites
superk888 4 Report post Posted August 12, 2017 check if they do count in the sqft for the entire room or they minus out the sqft for those area that has carpentry. my usual practice is install the entire plae and carpentry will sit on it for nicer overall touch. to minimise risk of scratching, install vinyl the day before carpentry or concurrently install if there are not many carpentry or just lay floor protection again to protect Share this post Link to post Share on other sites
Han Wei Aw 0 Report post Posted August 13, 2017 11 hours ago, superk888 said: check if they do count in the sqft for the entire room or they minus out the sqft for those area that has carpentry. my usual practice is install the entire plae and carpentry will sit on it for nicer overall touch. to minimise risk of scratching, install vinyl the day before carpentry or concurrently install if there are not many carpentry or just lay floor protection again to protect Thanks. Think I will just ask them to lay before any carpentry work. Share this post Link to post Share on other sites
Stream 4 Report post Posted August 13, 2017 The problem with laying vinyl under the carpentry is that in future, if you want to replace your vinyl flooring (it's not as durable as tiles), it's problematic. If cut round the base of the carpentry it will affect the look and then the remaining plastic will still stay trapped under the built-in furniture. Share this post Link to post Share on other sites
Lydia18 2 Report post Posted December 26, 2018 Hi peeps! Maybe this article may be of interests to you guys. It's about vinyl flooring. Have a read https://www.stoneamperor.com.sg/ecopluz/ Share this post Link to post Share on other sites
