jojo28
SOLID SURFACE COUNTERTOPS, NATURAL STONE COUNTERTOPS OR ENGINEERED STONE COUNTERTOPS: WHICH ONE IS FOR YOU?
Choosing a surface type for your new kitchen countertop is something that, for many of us, could be lifelong decision. What are the different types of surface materials available? How do they differ? Which surface type would suit your needs?
Solid Surface
Solid surface countertops are made from synthetic materials, usually out of acrylic or polyester. From a practical point-of-view, solid surface materials make a lot of sense and are popular choice for new homes especially in Asia. These surfaces are synthesized specifically to address major concerns regarding durability, hygiene and design in mind. Solid surfaces are a great alternative to natural stone and typically come in acrylic and polyester.
Non-porous
Pores are tiny openings over a surface which can be conducive spots for bacteria and other microorganisms to grow. Being non-porous means that solid surfaces are easier to keep clean and hygienic. The absence of pores also do not trap stains and is easy to clean with soap, water and cloth.
Versatile in design
Solid surfaces can be sanded and shaped into a wide variety of designs. Solid surfaces can be cut and joined in various configurations, which is a designer’s dream. Can be built in different orientations; horizontally or vertically.
Durability
More durable to impacts compared to natural stone due to its flexibility. Its softer surface is susceptible to cuts from knives. Granite stone is more resistant to heat and chemicals than marble.
Ease of repair
Light scratching and surface damage can be fixed with fillers. Entire portions can be cut out and replaced with new parts, and its uniform look (unlike irregular features of natural stone) makes it easy to blend in the replacement parts.
Cost
Expensive and comparable to natural stone.
Aesthetics
Many regard solid surfaces as lacking in the looks department compared to natural stone.
Natural Stone
Natural stone are heavy, slabs of rock cut and fashioned from large blocks from stone quarries. Natural stone is regarded for its beauty and have traditionally been used to build solid and long-lasting countertops. Notable examples of natural stone include marble and granite. Images of the Parthenon come to mind when we think of marble works and its association with grandeur.
Porous
Natural stone contains small pores that, if not treated with sealant, are a hygiene hazard as it traps bacteria and dirt. It is easy to clean when properly treated with sealant. Sealant needs to be reapplied every few years, or sooner as needed.
Less versatile
Solid blocks of stone are, as it is, set in stone. Seams will be very noticeable where two pieces of stone come together.
Durability
While very hard, natural stone is inflexible and brittle making it vulnerable to impacts and massive temperature fluctuations. Its hard surface, however, makes it very resistant to cuts and scratching from knives.
Ease of repair
Again, set in stone, natural stone is nearly impossible to repair. Depending on the severity of the damage, entire pieces may need to be replaced. The harder the stone is, the more difficult it is to repair.
Cost
Expensive. More so if repairs are ever needed.
Aesthetics
Widely regarded for its beauty. Aside from its patterns, cool look and glow, each slab of natural stone is unique and no two pieces are ever alike.
Quartz Stone
Not to be confused with its naturally occurring relative, quartz in countertop design are fabricated, yet retaining some of the aesthetics and durability that we associate with natural stone, with a few minor differences.
Quartz stone shares many similarities to natural stone. For one, it boasts a hardness of 7 on the Mohs Hardness scale (granite is 6-7, depending on its minerology) making it very resistant to cuts or scratching with sharp metal implements. In fact it might dull your knives instead! Quartz has a melting point of 1670°C (granite is 1215 – 1260°C) and is non-porous.
Quartz does discolour when exposed to sunlight. However, with darker colours, quartz stone can be put together in such a way that the seams are minimally visible.
After reading this article, YOU should know WHICH COUNTERTOP MATERIAL IS FOR YOU! :)
