paparazi257
Moving Tips: Moving the refrigerator safely
I think the most difficult furniture for us to move. I wanna share this article for you to get useful information. I translated into English.
Moving house - How to move the refrigerator is safe and effective?
Refrigerators are cool home appliances that are both convenient and necessary in every home. However, the refrigerator can easily be damaged during transportation if you do not move the refrigerator properly. Please join with NguyenloiMoving to find out through 8 steps to move your home completely.
Step 1: Take all the food out of the refrigerator
The first thing to do is to ensure that no food is left in the fridge as food and drinks can break, drop during transportation and cause the refrigerator to malfunction.
Step 2: Take out the tray tray
Removing all trays, ice compartments out is very useful because not only can the weight be reduced, but it also keeps the tray from being disturbed during transportation. However, note how to remove these trays so you can easily fit them in.
Step 3: Unplug the power cord
For safety reasons, be sure to remove the powerplug from the drive before packing and should be neatly folded to avoid interfering with the drive.
Step 4: Defrost and dry the cabinet before packing
Before you move at least 6 to 8 hours, flush the refrigerator. It will be very dangerous when there is snow or water on the move because of strong shaking, water may fall into the openings to damage the circuit. Not only that, if not dry very dry, the crowded closet will facilitate bacterial and mold growth. Therefore, after defrosting, use a dry towel to wipe off the stale water in the refrigerator.
Step 5: Freeze the refrigerator door.
You can use duct tape to fix the refrigerator door to help prevent the cabinet door from opening but do not tie too tightly because it can damage the fringe of the refrigerator.
Step 6: Cover.
If you move the refrigerator away, the refrigerator must be carefully packed by inserting layers of foam or cloth into the carton and sealed with newspaper or cloth, and then glued thoroughly.
Step 7: Carry lightly.
Move the cabinet lightly onto the trolley and use a fixed wire in the car. When renting a truck you need to make sure the transport company has specialized equipment to move the refrigerator. When moving the refrigerator, it is best to put the refrigerator in a working position. During the move, there should be support from at least 2 people, especially when up or down stairs you need to pay close attention and need healthy people to avoid collisions.
Step 8: Put the fridge in a new location.
After completing the move, the fridge can be placed in the position you have chosen before and can be used again. However, do not plug and use the cabinet immediately. It is best to allow 2 to 3 hours and then plug in the power to ensure safety.
Source: thuexetai.info
Translator: Helen Nguyen
