baldeagle
Kitchen Counter Top Replacement
On 7/28/2017 at 0:54 AM, baldeagle said:
Need to replace the counter top to solid surface or laminate.
Any recommended contractor for small job please?
Regards
You can contact Stone Amperor @ 88163033
Why replace your kitchen?
Is it worth the trouble?
After a number of years, your countertop may be suffering from stains, burn marks, and scratches. And the thing is, the scratches on your kitchen top will make it more prone to bacteria infestation…
that is a health hazard to your family, especially if you have little kids.
That is why you should invest in the replacement of your countertop every 3 – 5 years.
And before you get the new countertop, you should consider important factors such as:
  • Can your current kitchen cabinets withstand the new kitchen top? If you’re changing from plastic laminate or wooden countertop to a stone countertop, it’d wise to also upgrade your kitchen cabinets.
  • Your kitchen backsplash is usually connected to your countertop, so you’ll need to change it too. What material do you want to change it to?
  • Most probably you’ll need to change your sink as well. We’d recommend going for the cutting-edge under-mount Aura sink that gives you the non-leak warranty.
More at https://www.stoneamperor.com.sg/kitchen-countertop-replacement/
Maybe you could consider replacing your solid surface countertop to quartz countertop. Like other hard surface countertop materials, quartz is nonporous material. So it stands up to any liquid that can cause stain to the countertop. You could check Caesarstone for more information about quartz countertop.
Edited by jamielynambers029
