CJES 0 Report post Posted April 26, 2017 I just had my kitchen cabinets installed by my carpenter. When I open the cabinet door, it will always open more than 90 degree. If I open the left most or right most door, it will bang into wall. If open two doors side by side, it will bang into each others. I was advised to put rubber stopper to protect the doors. Is this normal for kitchen cabinet or my carpenter used cheap materials for my cabinet? Share this post Link to post Share on other sites
snoozee 98 Report post Posted April 26, 2017 perfectly normal. hinges normally open slightly more than 90 degrees. you can buy those small transparent semi-circular rubber bumps and stick on the wall or your cupboard doors to protect the doors. for the 2 side by side doors, just open them gently if you do not want to use the rubber stoppers. I used to have the rubber stoppers stuck to the wall to protect my fridge door handle as well. Share this post Link to post Share on other sites
skb 2 Report post Posted May 5, 2017 Agree that it is normal. It will be difficult to take/place things into the cabinet if the cabinet is deep and your door can only open 90 degree. Even more difficult if the cabinet has a narrow door. Share this post Link to post Share on other sites
Sabrina Ng 0 Report post Posted December 3, 2018 On 4/26/2017 at 4:29 PM, snoozee said: perfectly normal. hinges normally open slightly more than 90 degrees. you can buy those small transparent semi-circular rubber bumps and stick on the wall or your cupboard doors to protect the doors. for the 2 side by side doors, just open them gently if you do not want to use the rubber stoppers. I used to have the rubber stoppers stuck to the wall to protect my fridge door handle as well. Do you have picture of how these rubber stoppers look like? Can email me at sabrina.ng@gmail.com? Share this post Link to post Share on other sites
