EAX
Need Advice on Reno Quotation (5Rm BTO)
Hi guys, any advice regarding my following quotation? Carpentry is internal PVC. Thanks in advance!
PROFESSIONAL SERVICES
 1 Space planning and furniture layout
2 Design and furnishings consultation
3 Materials and colour proposal
4  Perspective visual drawings
5  Project management and site supervision
6 12 months home warranty
 $300.00
 MASONRY WORKS
 ( Living Room ) :
1 Supply material and labour to lay 600 mm x 600 mm homogeneous floor tiles c/w skirting
 ( Master Bedroom ) :
 ( Bedroom 2 ) :
 ( Bedroom 3 ) :
 ( Kitchen ) :
1  Supply material and labour to lay wall tiles as backing between top and bottom kitchen cabinet Dimension : L : 3150 mm x H : 650 mm
2  Supply material and labour to construct kitchen cabinet base Total size : L : 5250 mm x H : 50 mm
3  Supply material and labour to construct fridge base
 ( Master Bathroom ) :
1 Supply material and labour to construct shower kerb
 ( All selection of homogeneous / ceramic tiles are capped at $3.20 psf )
 $11,550.00
 ( Kitchen ) :
1 Supply material and labour to erect hollow brick wall between kitchen and living room Dimension : L : 2400 mm x H : 2400 mm
 $1,500.00
1  Supply material and labour to overlay 300 mm x 300 mm homogeneous floor tiles
2  Supply material and labour to overlay 600 mm x 300 mm homogeneous/ceramic wall tiles
 $2,300.00
 PARTITION WORKS
 1 Supply material and labour to erect top partition wall for veneer sliding door at master bedroom Dimension : L : 1100 mm x H : 450 mm
 $200.00
 FALSE CEILING WORKS
 1 Design and fabricate false ceiling with L-box design **** room ( as per design proposal )
 $650.00
 2 Design and fabricate false ceiling with L-box design at dining room ( as per design proposal )
 $400.00
 BI-FOLD DOOR WORKS
 1 Supply and install basic design bi-fold door at master bathroom ( basic design ) 2 Supply and install basic design bi-fold door at common bathroom ( basic design )
 $600.00
 GLASS DOOR WORKS
 1 Supply and install double panel 10mm clear tempered glass sliding door at kitchen entrance Dimension : L : 1500mm x H : 2100mm
 $1,180.00
 VENEER BEDROOM DOOR WORKS
1  Supply and install semi solid, veneer sliding door at master bedroom ( basic design ) - $1,100
2  Supply and install semi solid, rounded knob veneer swing door at bedroom 2 ( basic design ) - $300
3 Supply and install semi solid, rounded knob veneer swing door at bedroom 3 ( basic design ) - $300
 $1,700.00
 ALUMINIUM WINDOW WORKS
 1 Supply material and labour to install BA/NA colour aluminium sliding window at service yard
 $600.00
 ALUMINIUM WINDOW GRILLE WORKS
 1 Supply material and labour to install BA/NA colour aluminium window grille at living room ( horizontal design )
2 Supply material and labour to install BA/NA colour aluminium window grille at master bedroom ( horizontal design )
3 Supply material and labour to install BA/NA colour aluminium window grille at bedroom 2 ( horizontal design )
4 Supply material and labour to install BA/NA colour aluminium window grille at bedroom 3 ( horizontal design )
5 Supply material and labour to install BA/NA colour aluminium window grille at service yard ( horizontal design )
 $1,050.00
 SANITARY WORKS
 1  Supply labour to install kitchen sink and tap
2  Supply labour to install wash basin and tap for master bathroom 3 Supply labour to install instant heater
4  Supply labour to install 2 x bidet spray
5  Supply labour to install 6 x bathroom accessories
6  Supply labour to dismantle all bathroom fittings to overlay tiles at master bathroom 7 Supply labour to install water closet at master bathroom
8 Supply labour to install shower set at master bathroom
 $1,080.00
 PAINTING WORKS
 Supply material and labour to paint whole unit with Nippon Vinilex 5000 emulsion paint to all interior walls and ceiling
4 + 1 colours with 3 coatings include wall sealant
 $1,650.00
 1 Design and fabricate full height shoe cabinet c/w niche & swing door to laminate finish at living room Dimension : L : 1800 mm x D : 400 mm x H : 2400 mm
 $1,950.00
 2 Design and fabricate full height partial open concept TV cabinet c/w swing door to laminate finish at living room
Dimension : L : 2850 mm x D : 500 mm x H : 2400 mm
 $3,700.00
 3 Design and fabricate top and bottom kitchen cabinet c/w 2 tier stainless steel dish rack and swing door to laminate finish at kitchen
Total dimension for top cabinet : L : 4200 mm x D : 350 mm Total dimension for bottom cabinet : L : 4350 mm x D : 600 mm
 $4,350.00
 4 Design and fabricate full height tower cabinet to laminate finish at kitchen Dimension : L : 900 mm x D : 600 mm x H : 2400 mm
 $1,200.00
 5 Design and fabricate full height wardrobe c/w niche, swing door and 3 internal drawers to laminate finish at master bedroom
Dimension : L : 1800 mm x D : 600 mm x H : 2400 mm
 $1,950.00
 6 Design and fabricate full height wardrobe c/w aluminium sliding door and 3 internal drawers to laminate finish at bedroom 2
Dimension : L : 1650 mm x D : 600 mm x H : 2400 mm
 $1,950.00
 7 Design and fabricate full height wardrobe c/w aluminium sliding door and 3 internal drawers to laminate finish at bedroom 3
 $1,950.00
 8 Design and fabricate mirror cabinet c/w swing door to laminate finish at master bathroom Dimension : L : 1600 mm x D : 150 mm
 $1,070.00
 9 Design and fabricate suspended vanity cabinet c/w swing door to laminate finish at master bathroom Dimension : L : 800 mm x D : 500 mm
 $470.00
 QUARTZ WORK TOP
 1 Supply and install basic design quartz work top, 20mm single profile with back splash on kitchen bottom cabinet
Dimension : L : 4350 mm x D : 600 mm
 $1,800.00
 2 Supply and install basic design quartz work top, 20mm single profile on vanity cabinet at master bathroom Dimension : L : 800 mm x D : 500 mm
 $360.00
 GLASS WORKS
 1 Supply and install 10mm tempered glass shower screen c/w sliding door and stainless steel handle at master bathroom
 $590.00
 GENERAL WORKS
 1 Laying protection on flooring - $350
2 Disposal and clearance - $300
3 General cleaning upon completion - $300
 $950.00
Tiling all lump together with no floor area so difficult to estimate. But if your house is around 1000sqf then price is a little high.
wardrobe at $325 pfr is on the high side.
Kitchen cabinet at $150+ pfr is on the high side.
your quote is very expensive leh..my ID charge cheaper than that. Of course i went to check out the quality of his existing project.
Good workmanship and quality with affordable price..
Hi, the quote u received is on the high side..  Im an ID and i have indicate my pricing in red.The rest of items depends on the floor area.
All carpentry works in solid ply, internal coloured PVC, soft closing and ABS trimmings.
Feel free to PM me.
FOC
 MASONRY WORKS
 ( Living Room ) :
1 Supply material and labour to lay 600 mm x 600 mm homogeneous floor tiles c/w skirting Depend on area
 ( Bedroom 2 ) :
 ( Bedroom 3 ) :
 ( Kitchen ) :
1  Supply material and labour to lay wall tiles as backing between top and bottom kitchen cabinet Dimension : L : 3150 mm x H : 650 mm Depend on area
2  Supply material and labour to construct kitchen cabinet base Total size : L : 5250 mm x H : 50 mm $480
3  Supply material and labour to construct fridge base $150
1 Supply material and labour to construct shower kerb $120
 $11,550.00
 ( Kitchen ) :
1 Supply material and labour to erect hollow brick wall between kitchen and living room Dimension : L :2400 mm x H : 2400 mm
 $1200
 $2,300.00
 PARTITION WORKS
 $200.00
 FALSE CEILING WORKS
 1 Design and fabricate false ceiling with L-box design **** room ( as per design proposal ) Depend on area
 $650.00
 2 Design and fabricate false ceiling with L-box design at dining room ( as per design proposal ) Depend on area
 $400.00
 BI-FOLD DOOR WORKS
 1 Supply and install basic design bi-fold door at master bathroom ( basic design ) 2 Supply and installbasic design bi-fold door at common bathroom ( basic design )
 $600.00
 GLASS DOOR WORKS
 $1080
1  Supply and install semi solid, veneer sliding door at master bedroom ( basic design ) - $850
2  Supply and install semi solid, rounded knob veneer swing door at bedroom 2 ( basic design ) - $280
3 Supply and install semi solid, rounded knob veneer swing door at bedroom 3 ( basic design ) - $280
$1410
$560
 ALUMINIUM WINDOW GRILLE WORKS Depend on area
 1 Supply material and labour to install BA/NA colour aluminium window grille at living room ( horizontaldesign )
2 Supply material and labour to install BA/NA colour aluminium window grille at master bedroom (horizontal design )
3 Supply material and labour to install BA/NA colour aluminium window grille at bedroom 2 ( horizontaldesign )
4 Supply material and labour to install BA/NA colour aluminium window grille at bedroom 3 ( horizontaldesign )
5 Supply material and labour to install BA/NA colour aluminium window grille at service yard ( horizontaldesign )
Subj to window size
 SANITARY WORKS
2  Supply labour to install wash basin and tap for master bathroom 3 Supply labour to install instantheater
6  Supply labour to dismantle all bathroom fittings to overlay tiles at master bathroom 7 Supply labourto install water closet at master bathroom
$750
 PAINTING WORKS
 Supply material and labour to paint whole unit with Nippon Vinilex 5000 emulsion paint to all interiorwalls and ceiling
$1600
$1740
 2 Design and fabricate full height partial open concept TV cabinet c/w swing door to laminate finish **** room
$3515
 3 Design and fabricate top and bottom kitchen cabinet c/w 2 tier stainless steel dish rack and swingdoor to laminate finish at kitchen
Total dimension for top cabinet : L : 4200 mm x D : 350 mm Total dimension for bottom cabinet : L : 4350mm x D : 600 mm
$3705
 4 Design and fabricate full height tower cabinet to laminate finish at kitchen Dimension : L : 900 mm x D: 600 mm x H : 2400 mm
$1170
 5 Design and fabricate full height wardrobe c/w niche, swing door and 3 internal drawers to laminatefinish at master bedroom
$1560
 6 Design and fabricate full height wardrobe c/w aluminium sliding door and 3 internal drawers tolaminate finish at bedroom 2
$1760
 7 Design and fabricate full height wardrobe c/w aluminium sliding door and 3 internal drawers tolaminate finish at bedroom 3
$1760
 8 Design and fabricate mirror cabinet c/w swing door to laminate finish at master bathroom Dimension :L : 1600 mm x D : 150 mm
$770
$390
 QUARTZ WORK TOP
 1 Supply and install basic design quartz work top, 20mm single profile with back splash on kitchenbottom cabinet
 $1305
 2 Supply and install basic design quartz work top, 20mm single profile on vanity cabinet at masterbathroom Dimension : L : 800 mm x D : 500 mm
$270
 GLASS WORKS
 1 Supply and install 10mm tempered glass shower screen c/w sliding door and stainless steel handle atmaster bathroom
 $590.00
 GENERAL WORKS
 $950.00
Edited by peihao83
I just did my my home, previously i went around to look for many quotes from many different companies. And finally came to a conclusion that diff id company quotation are diff as  only they themselves know what they are quoting as design and materials used are diff, some tried to pull a quick deal off where they themselves are not sure and not knowledgable. I personally feel that having a responsible contractor or ID is very important.
In the end decided to use a ID that is introduce to me by a friend which have engaged their service before.
If u really need my ID or Contractors contact feel free to let me know
I noticed that there are some some erection of walls. Just to highlight in case you do not know about this.
For erection of walls, the contractor will need to apply approval from the HDB. Then the HDB will decide if you require to engage a PE(Civil) to endorse. (which will involve some costs which can range from a few hundreds to $1k depending you find on your own or leave it to the contractor.)
It is up to HDB to decide if PE(Civil) is needed or not. You can PM me if HDB requires the endorsement.
Thanks.
