RachelJill
Advice on quotation
Hi all,
Just received this quotation from my ID, is this reasonable? Please help to advice.
Thanks.
  : QUOTATION FOR THE ABOVE PREMISES INTERIOR DESIGN & RENOVATION WORKS
    Promotion package for kitchen package :
    Demolition Works
1   Dismantle existing kitchen cabinet
2   Demolish existing kitchen floor tiles.
3   Demolish existing kitchen wall tiles.
    Masonry Works (homogeneous/ceramic tiles base on $3.40 psf)
4   To supply & apply per pack 3 in 1 cement for kitchen floor.
5   To supply & apply waterproofing for kitchen flooring.
6   To supply & lay homogenous floor tiles for kitchen.
7   To supply & apply per pack 3 in 1 cement for kitchen wall.
8   To supply & lay ceramic wall tiles for kitchen.
9   To supply & construct fridge base.
10   To supply & construct washer base.
    Carpentry Works (laminated finish)
11   Supply & fabricate 20ft(L) top & bottom kitchen cabinets in laminate finish c/w ABS
12   door frame trimming & soft closing for drawers & doors.
13   Supply & install 10ft(L) quartz worktop for kitchen cabinets. At $100 pfr
    Plumbing Works
14   Connection of inlet / outlet for kitchen sink & washing machine tap.
    Miscellaneous Works
15   Cardboard protection for affected areas.
16   Chemical washing & General cleaning upon completion.
      TOTAL   $9,988.00
    Demolition Works
1   Demolish existing wall tiles for common toilet.     $600.00
2   Demolish existing floor tiles for common toilet.     $300.00
3   Demolish existing sink & stove support.     $300.00
4   Dismantle sanitary ware & accessories for 2 bathrooms.     $100.00
5   Demolish existing all doors & gate.(total 7 no's)     $210.00
      TOTAL   $1,510.00
1   To supply & construct sink & stove support. 10ft(L)     $1,200.00
2   To supply & lay waterproofing membrane for master toilets flooring.     $150.00
3   To supply & overlay homogeneous flooring  for common toilet.     $500.00
4   To supply & apply per pack 3 in 1 cement for master toilet floor.     $100.00
5   To supply & lay homogeneous flooring  for master toilet.     $500.00
6   To supply & apply per pack 3 in 1 cement for master toilet wall.(180 sqf x $2)     $360.00
7   To supply & lay ceramic wall tiles till ceiling height for master toilet.(180sqf x$7.00)     $1,260.00
      TOTAL   $4,070.00
    Plastering Works
1   Supply & plaster living, dining & 3 bedrooms interior wall & ceiling.     $1,800.00
2   To supply & plaster kitchen & 2 toilets ceiling.      $400.00
      TOTAL   $2,200.00
    Electrical Works supply & install : (estimate)
1   lighting point 18 @ $35.00   $630.00
2   Single power point 13 Amp ( fridge, washer, room) 04 @ $50.00   $200.00
3   Double power point 13Amp (living 3, dining 1, kitchen 2, room 2) 06 @ $60.00   $360.00
4   Heater/air con point 15Amp. 02 @ $100.00   $200.00
5   Oven / hood point 15Amp. 02 @ $100.00   $200.00
6   Installation of ceiling fan, hanging light. 05 @ $45.00   $225.00
7   Installation of down light, ceiling light. 13 @ $10.00   $130.00
8   TV(scv) point. 01 @ $90.00   $90.00
9   New DB box     $350.00
      TOTAL   $2,385.00
    Air con Works
1   Supply aircon piping & relocated for 3 bedroom.     $1,100.00
      TOTAL   $1,100.00
    Plumbing Works
1   Supply & install (cold)stainless steel piping for whole house.     $690.00
2   To provide labour to install 02 set of Water closet.  ($80 each)   $160.00
3   To provide labour to install 02 set of wash basin. ($50 each)   $100.00
4   To provide labour to install accessories for 02 Bathrooms. ($50 each)   $100.00
5   To provide labour to install 02 no's instant heater ($50 each)   $100.00
6   To provide labour to install 2 no's water sprayer.  ($40 each)   $80.00
      TOTAL   $1,230.00
    Ceiling Works
1   To supply & install partial false ceiling & box up for living & dinning hall      $800.00
2   To supply & install half height partition board **** hall.     $400.00
3   To supply & install partition at master room. 7ft x 7ft     $300.00
4   To supply & install extra box up for curtain pelmet & aircon/water piping.     $500.00
      TOTAL   $2,000.00
    Painting Works (1 coat of sealer & 2 coats of paints)
1   Painting of whole house(wall / ceiling) using Nippon emulsion paint.     $1,200.00
2   Supply & paint water based sealer for whole house.     $300.00
3   Painting of all pipes & door frame using gloss finish paint.      inclusive
      TOTAL   $1,500.00
    Doors/gate/Glass/mirror/window/grilles Works
1   Supply & install solid wooden main door.     $580.00
2   Supply & install total 3 no's solid wooden door for bedrooms. ($280 each)   $840.00
3   Supply & install 1 no's wrought iron main gate. Size : 3ft x 7ft      $450.00
4   Supply & install alum bi-folding door c/w top hunt for both toilets. ($250 each)   $500.00
5   Supply & install 10mm tempered glass shower screen for master toilet.     $620.00
6   To supply & install 1 sets louver window c/w adjustment for master toilet.     $280.00
      TOTAL   $3,270.00
    Living Hall
1   Supply & fabricate full height altar table . 5ft(L) x $220     $1,100.00
    Master Bedroom
2   Supply & fabricate extent full height wardrobe .4.5ft(L) x $260     $1,170.00
    (Kitchen)
3   Supply & fabricate 5 no's wooden laminate door. At $80 each     $400.00
4   Supply & fabricate 4ft(L) top & bottom kitchen cabinets in laminate finish c/w ABS     $480.00
5   door frame trimming & soft closing for drawers & doors. At $120pfr
    To provide labour to install drip tray, hood & hob.      inclusive
      TOTAL   $3,150.00
      GRAND TOTAL   $32,403.00
      LESS top 2ft   $200.00
      FINAL   $32,203.00
it look weird to me. Because i dont trust quotation that is in lump sum.
I want to see each item in details.
And i don't see why the hacking of sanitary ware are charged again?
I did my resale reno too. I just feel the quote is suspicious.
Pardon me if i'm too busybody.
Hi zph19101,
Thanks for your comment and I really appreciated.
Renovation process really a very big "project" in life and really need to put in lots of efforts.
The lump sum figures in the quotation is their current resale kitchen package and added master bathroom, electrical, plumbing, plastering, carpentry...
On 3/22/2017 at 0:55 PM, RachelJill said:
Hi zph19101,
Oh ic.. I don't trust package. Because everything is lump sum. Some sort of hidding every items price. We don't know the pfr price from package too.
