taurusgal56
Walk in wardrobe with doors
Hi guys! I'm new to this forum or any Reno forum to be exact. I need help urgently to decide whether we go for engaging and ID or sourcing for carpenters to do the carpentry work. Work to be done is not a lot, basically main works will be a walk in wardrobe concept for 1 of the rooms ( U shaped meaning 3 of the walls will be filled with wardrobes with doors). And false ceiling and tv feature wall plus cabinets, console).
Does anyone know of any wardrobe carpentry specialists to recommend? I was quoted a ridiculous amount of 15k just for the wardrobes due to spray painting which was said to be more expensive ( due to trimmings as I wanted a white Victorian look) OR about 7k for just a normal laminate finish. Was just wondering if not engaging an ID for fhis will be cheaper?
Hi, I also thought of doing spray painting on carpentry for my Victoria wardrobe and cabinet. I almost fainted when I saw the price. Haha.
So I went to did it with carpentry. Turn out to be  better than what I expect. Here are some photos.
1 hour ago, taurusgal56 said:
Thanks! Do u mind sharing which carpentrr you engaged and the amount that you spent roughly?
Hi, Im pm you k.
3 hours ago, cymon said:
Hi zph19101
Care to share how to your carpentry charge for your Victoria lookalike cabinets ($/sqft)?
Thank you.
Hi, it was done by my ID.
You can call him at 861722982 chris.
Cheers
  • Like 1
Cheers
HP number extra digit. :D
Anyway, thank you for the recommendation.
