revolver80
Need Advise On 4 Rm Resale Reno Quote
Hi everybody, need some advise on the quotation that I got from my designer. I'm doing up a 4 RM resale and the quotation is way above my budget of $25K.
Besides reducing carpentry works, where else can I save money on? Am I over quoted for any of the items?
I did some research and it seems that the lamination and re-wiring is on the high side. Do you guys agree?
Also, anyone have any idea what is the cost for these 2 items?
4 All permit fees to HDB, MOE, Pub & management deposit if any By owner
5 All submission fees to relevant authority pertaining to renovation works approval By owner
Any advise will be greatly appreciated.
Thanks !!
A DESIGN AND SUPERVISION SERVICES
1 Proposed design and space planning service F.O.C
2 Proposed perspective design and drawing of all carpentry works F.O.C
3 Proposed colour schemes, materials and accessories F.O.C
4 Professional projection co-ordination and site supervision F.O.C
B DEMOLITION WORKS
1 Labour to hack existing floor & wall tiles @ 2 Bathrooms & Kitchen incl dismantle all sanitaryware LS $2,000.00
2 Labour to hack existing partition wall between Masterbedroom & Bedroom 1 incl making good LS $380.00
3 Labour to hack existing partition wall between Kitchen & Masterbedroom LS $320.00
4 Labour to hack new doorway for Masterbathroom LS $120.00
5 Labour to remove existing kitchen cabinets LS $200.00
6 Labour to remove all existing bedroom & toilet doors LS $90.00
C CONSTRUCTION / WET WORK
1 Supply & lay selected 600 X 600 homogeneous floor tiles incl waterproofing works for kitchen & Yard Area (Tiles < $3.50) LS $2,100.00
2 Supply & lay selected 300 X 300 homogeneous floor tiles incl waterproofing works for 2 toilets area (Tiles < $2.50) LS $600.00
3 Supply & lay selected ceramic wall tiles for bathroom (Tiles < $2.50) LS $3,000.00
4 Supply labour & material to plaster smooth all walls for Kitchen LS $1,650.00
5 Supply labour & material to seal existing doorway to Masterbedroom & Masterbathroom LS $500.00
6 Construct concrete plinths for kitchen cabinet & washing machine & fridge base LS $340.00
7 Supply labour & equipment to polish existing marble flooring **** Area LS $680.00
D LAMINATED FLOORING
1 Supply & install selected laminated flooring to 3 bedrooms (SUPREME LAMINATE or POWER DEKOR) LS $2,000.00
E PAINTING & WALLPAPER WORK
1 Whole house painting (3 coats) with ICI Pentalite or Nippon Vinnilex 5000 incl door frames & exposed pipes - no restriction to nos. of colours LS $1,200.00
2 Supply labour & material to paint main door LS $100.00
3 Supply & install selected wallpaper to TV feature wall @ Living Area LS $750.00
4 Supply & install selected wallpaper to bed-head wall @ Masterbedroom LS $750.00
F CARPENTRY WORK
Foyer
1 Design & fabricate full-height shoe cabinet with laminated finished swing doors 3 ft $750.00
Living Hall
2 Design & fabricate low-ht/suspended TV console w laminated finish 6 ft $900.00
Master-bedroom
3 Design & fabricate full-ht wardrobe c/w shelves, railings & chest of drawers w sliding doors finished in laminate & glass 9.5 ft $2,565.00
4 Design & fabricate island study table cum half-ht TV feature wall finished in laminate & glass 5 ft $875.00
Bathrooms
5 Design & fabricate suspended vanity counter cabinet w laminate finish c/w wall-mounted mirror 2 nos $800.00
6 Supply & install CRESTO solid surface counter-top c/w backsplash & side profile 3.5 ft $400.00
Kitchen
7 Design & fabricate island bottom kitchen cabinet w laminate finish & ABS trimming 11.5 ft $1,610.00
8 Supply & install CRESTO solid surface extra-wide counter-top 16.5 ft $1,250.00
9 Design & fabricate tall unit w swing doors w laminate finish & ABS trimming 5.5 ft $1,375.00
10 Design & fabricate hidden cooker hood & hob tall unit w sliding door w laminate finish & ABS trimming 5 ft $1,350.00
G CEILING WORKS
1 Construct false ceiling & L-box design for Foyer, Living Area & Masterbedroom LS $1,500.00
H ELECTRICAL & PLUMBING WORKS
1 Supply labour & material to re-wire whole house incl. Labour to install light fittings LS $2,400.00
2 Supply labour & material to re-run stainless steel piping for whole house incl. Labour to install sanitaryware LS $1,500.00
I DOORS & GRILLE GATE
1 Supply & install doors & gate (c/w all necessary satndard ironmongery) as below :
I) Nyatoh ply doors (existing door frames) to Bedroom & Store entrances 3 nos $660.00
II) Frameless 10mm thk clear tempered glass pivot door to Kitchen entrance 1 nos $450.00
III) Powder coated bi-fold doors c/w acrylic panels to Bathroom entrances 2 nos $400.00
J MISCELLANEOUS
1 To supply and lay corrugated paper roll to whole house for general protection LS $120.00
2 Provision for haulage of material & clearing of debris upon completion of work LS $350.00
3 Supply labour & material to wash whole unit after renovation works LS $200.00
Total $36,235
Special Discount $1,735
Grand Total For The Above Mentioned Renovation Works $3,4500
not very sure for the rest of the items but
re-run stainless steel piping for whole unit - $550
(labour to install bath acc free but not sure about WC and basin)
paint whole unit including piping, doors, frames etc $1300 (nippon 3-in-1)
my flat is EA 134sqm
Edited by applefreak
Thanks !!
B DEMOLITION WORKS
Overall their hacking is still ok. but make sure that all will be make in good finish after hacking is done.
It will be good to know what is ur total area of ur kitchen and service yard area and plus a 5% wasteage.
then u will know is it worth while for ur kitchen.
also how many layers of waterproofing they will be giving to you.
same as above.
same as above.
How much they charge u psf? and also what is ur total sqft for all 3 bedrooms?
this one mention above is an extra charge. it should be together with the whole house painting.
F CARPENTRY WORK
For all laminated finish under this make sure that what are the brands u are allow to used. If not when u want to choose other brands they will charge u extra.
Foyer
Living Hall
if just onli a plank of wood then i rather u save it and get a better design from outside.
Master-bedroom
What type of glass can u choose? frosted/clear or sandbrass(not sure spell right or not?)
also ask for free full height mirror.
Bathrooms
Kitchen
G CEILING WORKS
J MISCELLANEOUS
make sure that all the debris will be clear off by the contractor. if not HDB will charge u. This happen to one of mine neighbour. They make a big fuss out of it.
Total $36,235
From the overall quotes take a look on the capentry side and hacking. This two will be the most expensive and it already took about half of it already. So it u can minimize the carepentry work and hacking then u will save quite a lot on it.
Do look for more quotes.
Hi there, this is my first time posting. I just bought a 5-rm resale flat and the square area is almost similar to yours 133sqm.
Do you mind sharing your ID and their quote to me? PM me can?
