Emilita Lim
Renovation Packages (HELP)
Hi forumers, I need your help, to see if the reno company's quotation is reasonable. Let me know your thoughts.
A Demolition Works
A.1 To hack off existing Wall at kitchen area(balance 1m from floor keep) 720
Approx Size: L2200mm H1600mm
A.2 Submission of professional engineer FOC
A.3 Haulage services 750
A.4 Removal & disposal services FOC
A Subtotal 1470
B Masonry Works*Inclusive of the use of prepacked materials mandated by HDB(excluding tiles)
B.1 To supply materials & labour to lay 60 x 60 polished homogeous tiles/w skirting at floor of Living & 3630
dining room. *based on $3.00 psf tile
B.2 To supply materials & labour to lay 60 x 60 polished homogeous tiles/w skirting at floor of master 1990
bedroom. *based on $3.00 psf tile
B.3 To supply materials & labour to lay 60 x 60 polished homogeous tiles/w skirting at floor of bedroom 2 1320
B.4 To supply materials & labour to lay 60 x 60 polished homogeous tiles/w skirting at floor of bedroom 3 1290
B.5 To supply materials & labour to make to good hacking area wall(kitchen) excluding tiles 500
B.6 To supply materials & labour to construct 50mm cement kitchen cabinet base 550
B.7 To supply materials & labour to construct shower curb at master bathroom 180
B Subtotal 9460
C Plumbing Works
C.1 To supply labour to install kitchen sink & tap after carpentry work 120
C.2 To supply materials & labour to install 2 nos hot water points 200
C.3 To supply labour to install 2 nos Shower mixer 180
C.4 To supply labour to install 2nos water heater or instant heater 120
C.5 To supply labour to install 2 nos toilet spraygun 80
C.6 To supply labour to install bathroom accessories FOC
C Subtotal 700
D Aluminium / Glass Works / Wrought Iron
D.1 To supply materials & labour to install fixed panel 10mm tempered glass at kitchen area 570
Approx size: L2100mm H1600mm
D.2 To supply materials & labour to install 5mm clear mirror for shoe cabinet 250
Approx size: L500mm H2000mm
D.3 To supply materials & labour to install fixed panel with casement 10mm tempered glass shower 480
screen at master bathroom. Approx size: L1500mm H1800mm
D.4 To supply materials & labour to install sliding door with fix panel with 10mm tempered glass at 750
kitchen entrance area. Approx size: L1100mm H2100mm
D Subtotal 2050
G Miscellaneous
G.1 To supply materials & labour to paint whole house ceiling & wall using Nippon Venillux 5000 1450
emulsion paint.( 5 colors including white)
G.2 To supply materials & labour to paint whole house gate, door, door frame, pipe & etc FOC
G.3 To supply materials & labour to lay cardboard protection at areas of work FOC
G.4 General Cleaning for whole house upon completion 250
G.5 Acid washing for whole house to remove stains 250
G.6 To supply materials & labour to install Mitsubishi system 4 inverter at master, common 2 , 3 & study room (4A28VAMSY. GE10VA *3MSY. GE18VA*1) 3950
G Subtotal 5900
H Budgetary Carpentry Quotation ( Prices are subjected to change at final design & material stage )
Kitchen
H.1 Design, fabricate & install top & bottom Kook's kitchen cabinet . 3260
• Designer Kitchen Cabinet
• ABS Laminated Door
• Aluminium glass door
• Coloured PVC Internal Finish
• slow close/anti-slam hinges
• slow close/anti-slam drawers
• 1 set "BLUM Aventos" Pull Up Slow Close Door
• 1 No Stainless Steel Dish Rack
• solid plywood
Approx sze: L6200mm x H850mm x D600mm/D350mm
H.2 To supply material & install selected 15mm Quartz worktop. 1370
Approx sze: L3100mm x D600mm
H.3 To supply material & install selected 12mm'' Bellus''solid-surface worktop 450
Approx sze: L1500mm x D600mm
Living Area
H.4 Design, fabricate & install full height shoe cabinet w/settee and display with solid plywood/finished 1820
in color PVC, laminate. Approx Size: L 1000mm H2550mm D450mm
Master Bedroom
H.5 Design, fabricate & install built-in full height sliding wardrobe with solid plywood finished in color 4650
PVC & laminate. Approx size: L4500mm H2550mm D600mm
H.6 To supply materials & labour to construct one step platform(Include 1 small step to platform) with 2350
storage at side and top in selected laminate finish at master bedroom.
Approx size: L2800mm x D2200mm X H300mm
Dining Room
H.7 Design, fabricate & install island w/settee and display with solid plywood/finished in color PVC, 1250
laminate. Approx Size: L 1500mm H750mm D600mm
H Subtotal 15150
Please let me know asap....
6 hours ago, Emilita Lim said:
How about this? This is from another firm..
Price is reasonable. But all your carpentry come with internal white PVC, no soft closing, casement instead of sliding doors.
1 hour ago, Emilita Lim said:
@Hwmook ya i was wondering about that too.. but the rest seems reasonable enough right?
Yes, reasonable enough. Internal coloured PVC, blum soft closing hinges and sliding doors all cost extras so you might want to take note of that. Usually contractors quote base on the cheapest options then top up as you add on while ID will likely quote base on the most popular options.
