doreamon
Aircon
Hi all,
Anyone know which brand offer good good n cheap cheap system 2 aircon ?? Cos we already spent alot on reno n some elect item so was thinking to save on aircon .... actualli we seldom on aircon one... our current place one i think we onli on ard less than 10 times a year... (sometime juz on it for abt 15 mins for the sake of running it .....) .. we wanted to have sys 4 in the begining then later thinking of we seldom use so we onli intend to have it in our MBR n my mom's room ...
thanks a advance ....
kekeee our budget ard $1200 (its best that dun wan those big big old old fashion one ....)
you can try the few air-con shops at IMM
got a system 3 at $1669 so system 2 should fit your budget
the guy recommended LG, which according to the NEA site is the most energy efficient
maybe you want to decide on the brand first then go down to ask the price
also make sure that the price you pay includes all the necessary installation e.g. min class 1 insulation, min gr 23 copper piping, 16mm piping etc... got all these info from other thread in renotalk. do some search and you wlll know which shop to go :bangwall:
oooo okie noted ... will rem to quote LG when we are sourcing ....
just my 2 cents... that LG model only has 1 compressor... meaning if you switch on for 1 room, it's still zaps maximum electricity..
hmmm mostly onli one compressor rite ?? i meant see those flat one, most of the houses onli got one compressor ....
that's the outdoor unit... within the outdoor unit you can have 1 or 2 compressors.
most japan (non-inverter) models have 2 compressors for system-3.. so that you can use the smaller capacity one for the frequently used room... use less electricity.
my home rarely use air-con
think current home max one year on 10 days nia
so the only time air-con is on will be when it's super hot, then all 3 will be switched on :dancingqueen:
thanks for the heads up
guess that's a consideration for those buying air-con, only use one frequently or usually all on...
