Cheng Yang Lee
Quote reasonable?
Dear All, I am renovating my resale 4 room HDB. The below was quoted to me by an ID firm which I thought it is on a high-side. I am going through HIP program soon(no confirm date yet but polls went through) so both toilets, rubbish chute and iron wrought gate are inclusive in the program.
Due to tight budget, I need advice whether the market rate are as quoted. If yes, I would probably hold the renovation works till HIP. Thanks.
1.0 DEMOLITION WORKS
To dismantle & remove existing:
1.1 kitchen cabinet $ 300.00
1.2 sink & stove support $ 300.00
1.3 laminate floorboard ****/dining & 3 bedrooms. Area: 770sf $ 650.00
1.4 plaster light holder **** $ 380.00
1.5 wardrobe at Bedroom 2 $ 250.00
1.6 4 nos.of doors $ 120.00
1.7 Haulage, clear debris & acid wash kitchen $ 680.00
2.0 MASONRY WORKS
To supply labour & material to overlay:
2.1 homogenous floor tiles to kitchen c/w water proofing $ 1,700.00
2.2 ceramic wall tiles to ceiling height. Area: 450sf $ 4,950.00
2.3 50mm fridge base w/tiles at vertical & horizontal surface $ 500.00
2.4 kerb w/ tiles to door entrance $ 250.00
2.5 High end resilient flooring to living/dining & 3 bedrooms(w/o skirting)Area: 830sf $ 5,810.00
3.0 PLUMBING WORKS
3.1 To supply labour & material to install stainless steel piping cold water point only to both toilet $ 500.00
3.2 Installation of inlet & outlet for washing machine at kitchen $ 150.00
3.3 Installation of inlet & outlet for kitchen sink $ 150.00
3.4 Installation of temporary water point if require $ 80.00
*Note: all sanitary wares purchased by owner
4.0 MISCELLANEOUS WORKS
4.1 To supply & install silver aluminium Casement Window frame w/ infill tinted black glass pane to whole house except toilets.
      Area: 130sf $ 2,080.00
4.2 To supply & install silver aluminium sliding grilles to whole house except toilets. Area" 130sf $ 1,000.00
4.3 To supply labour & material to smoothen interior wall & ceiling w/ plaster $ 3,200.00
4.4 To supply & install frameless tempered glass sliding door w/ top hung at kitchen $ 850.00
4.5 To supply & install L shape plaster false ceiling w/ light holder **** $ 650.00
4.6 Painting of whole unit internal walls with NIPPON paint, ceiling in matex white c/w Sealer $ 1,680.00
4.7 To supply & install 4 nos. of timber veneer door c/w standard lockset $ 1,320.00
5.0 CARPENTRY WORKS
5.1 To fabricate & install kitchen cabinet in selected laminate finish c/w1 chest of drawer & dish drying rack. Size:23'L $ 5,520.00
5.2 Supply & install 19' length selected solid surface worktop to kitchen cabinet 22" $ 1,330.00
5.3 To fabricate & install full height built-in wardrobe c/w swing doors panel in selected laminate finish at Master Bedroom. Size: 6'Lx8'H $ 1,440.00
     *Note: all internal cabinet in PVC white & soft closing hinges
6.0 Electrical Works(Provisional only)
6.1 Supply labour & materail to install:
6.2 25 nos. of lighting Point @$38each $ 950.00
6.3 11 nos. of 13Amp double power socket outlet @$65each $ 715.00
6.4 4 nos. of 13Amp single socket outlet @$55each $ 220.00
6.5 2 nos. of Data point @$120each $ 240.00
6.6 1 no. of 20Amp aircon point $ 120.00
6.7 1 core wire to cooker w/ switch $ 65.00
6.8 3 nos. of SCV point @$120each $ 360.00
6.9 2 nos. of heater point @$120each $ 240.00
6.10 1 no. of oven point $ 120.00
6.11 24 nos. of light fitting @$10each $ 240.00
6.12 Installtion of 1 nos. of ceiling fan @$50each $ 50.00
6.13 I set of DB board $ 350.00
Total: $39510
