Junkay
Funny Tasting Water
Has anyone ever encountered funny tasting water after u boil it in the thermopot thingy. I did what the instruction booklet say, boil one time and dispense the water out for the first time. Thing is, straight up from the tap and cooled, it tastes fine but once its boiled, man its funky.
Any gurus out there?
You might want to try boiling with another kettle.. to see if it's the water problem or the kettle problem.
I'm also using the electric boiler, so far no problem leh..
If it's the problem with the water, (After trying with another kettle) then you can give town council a call..
if i dont have another kettle? can i just boil it on the stove and test?
Can.. as long as you use other thing to boil beside the boiler.
I doubt it's the water problem lah.. cos if it's the water problem, then they should taste wierd too right from the tap. But you better test, just to be sure.. :thumbs up:
