Chong Xun
Need help on Quotation - resale flat 5room
Dear Master,
This is my first time to renovate the house. Please advise whether the below quotation received is reasonable.
Thank you
A) Hacking & Dismantlin Works
Hack off existing wall tiles and floor tiles including dismantling existing kitchen cabinets and sink cabinet and base and toilet bowl and wash basin at kitchen and 2 nos toilets                  1,900.00
Demolition off existing brick wall and aluminum sliding door                     950.00
Dismantle existing laminated flooring with skirting and cabinet and furniture and wardrobe                     950.00
B) Living , dining , balcony & 3 nos Bedrooms
Supply & overlay homogeneous floor tile with skirting **** , dining , balcony and 3 nos bedrooms (not exceeding $4.00 sq ft)                  8,100.00
SuppIy and box-up cement board partition wall for balcony main pipe Supply and replace I nos window grille lock set and stainless steel lock set and metal gate stopper                     505.00
Supply and replace wooden classic door for 3 nos bedrooms                     540.00
C) Kitchen
Supply & overlay homogeneous floor tile at kitchen ( not exceeding $4.00 sq ft)                  1,450.00
To construct 50mm kitchen cabinet ,base fridge base, washing machine base for Kitchen cabinet                     450.00
Supply & lay ceramic wall tiles with 3-in-l wall cement for Kitchen  ( not exceeding $4.00 sq ft)                  4,500.00
To design & fabricate 34 feet Top & Bottom Kitchen cabinet with solid plywood in laminated finishing with soft closing door( include box up kitchen main pipe )                  4,320.00
To supply, fabricate & install 1 7 feet granite top with backsplash & front profile for Kitchen cabinet                  1,700.00
Supply & install inlet & outlet piping for kitchen sink & washing machine                     160.00
Supply & install stainless steel water piping for Kitchen                     380.00
Supply and install aluminum PD door at kitchen entrance (1600mm X 2150mm)                     950.00
D) Master Toilet & Common Toilet
Supply & lay homogeneous floor tiles with waterproofing & 3-in-l floor screeding for 2 Toilets (600mm x 150mm, tiles not exceeding $4.00 sq ft)                  1,300.00
To provide waterproof treatment flooring for 2 toilets                     500.00
Supply & lay ceramic wall tiles with 3-in-l wall cement screeding to full height for 2 Toilets (600mm x 150mm, tiles not exceeding $4.00 sq ft)                  4,500.00
Supply & install stainless steel piping cool and hot water pipe for shower at 2 Toilets                     600.00
Installation of 2 nos of toilet bowl, 2 nos ofwash basin, storage heater & bathroom accessories, etc. for 2 Toilets                     550.00
Supply & install inlet & outlet piping for 2 nos toilets wash basin                     160.00
Supply & install 2 nos of PD door for 2 Toilets                     640.00
Supply and install 1 Omm temper glass sliding door shower screen for master toilet                     580.00
Supply and construct vanity support with granite top  for master toilet (1500mm X 600mm)                  1,500.00
E) Electrical Works
Hack and relocate conceal lighting point 4 nos and socket and make good plaster **** hall                     250.00
F) Miscellaneous Items
Clearing of debris & protection covering for flooring                     550.00
Acid washing & general cleaning for whole house                     250.00
To rovide painting service for whole house & 3 nos bedroom door , store romm , main door                  1,650.00
Discount               (1,885.00)
Total amount               38,000.00
14 minutes ago, Chong Xun said:
Dear Master,
Thank you
C) Kitchen
E) Electrical Works
Discount               (1,885.00)
it could be lesser? try nego with your contractor
