Jigsaw 0 Report post Posted July 14, 2016 Need some advice whether this is a good idea. Some do not recommend due to oily kitchen. Also what is the estimated costs. Share this post Link to post Share on other sites
Darren Tan 0 Report post Posted July 15, 2016 Are you thinking of engaging someone to do or want to DIY? I check with one contractor before, the driver for the led strips alone cost hundreds and i still can't figure out why is it so expensive. Share this post Link to post Share on other sites
w7_lee 11 Report post Posted July 15, 2016 It's more for aesthetic purpose only, does not serve any practical purpose. If cost is an issue, then ask contractor to use normal lighting. IKEA also sell a light that can be use for this purpose and can DIY but need to provide a power supply below (somewhere) your cabinets. Share this post Link to post Share on other sites
Jigsaw 0 Report post Posted July 15, 2016 Thanks for the advice guys. Share this post Link to post Share on other sites
samyee 1 Report post Posted September 7, 2016 can go and research on some sites that provides price comparison tool, usually they will provide the price together with the installation guy, but better to compare the prices first la, and if can DIY, why not? Share this post Link to post Share on other sites
skytart 0 Report post Posted December 7, 2016 anyone where to buy the driver and the led strip and roughly how much the driver and led strip cost? what size does the led strip come in? Share this post Link to post Share on other sites
Jethro 0 Report post Posted January 5, 2017 LED strip is $6/m with driver is less than $30. Just stick the strip below the top cabinets. Share this post Link to post Share on other sites
ARTnLIFE 0 Report post Posted March 4, 2017 The 3 common LED lights for kitcehn wal cabinet are [A] led long ( cut to desired length ) strip light, round cased light [C] LEd tube light with in-built led driver Option [ A ] is mostly placed at the rear , underside of the owall cabinet , against the wall Optrion is normally at the center, underside of the wall cabinet Option [ C ] is normall placed at the front , underside of the wall cabinet , but requires a wood pelmet strip in front conceal the slight bulky tube light Yes, all requires power souce. Thouse without in- built LED driver are normally placed in the false ceiling of the top of the wall cabinet ( assuming the power source is around that area. ______________________________________ Vist my Artbuilt Blog @ http://artbuilt.blogspot.sg/ Share this post Link to post Share on other sites
NateFolzer 4 Report post Posted July 23, 2021 I tried to hide it under the countertop. Share this post Link to post Share on other sites
Ciel2333 0 Report post Posted December 6, 2021 You should consider the price of wirings, LED light and power connection. I have a hollow cabinet bottom and hide the wirings in. I also have a paper towel holder under the cabinet to make it a modern look. Share this post Link to post Share on other sites
