newaisa 0 Report post Posted June 27, 2016 Hi Guys, Was changing the power socket and light switches for my place. Everything went well, except when I was disassembling one of the light switches, I realized they are all the same color (too late, cos I have removed the connections, wrong move I know) Moving forward, how can I be sure which wire is Live, Neutral, Ground. My apartment color coding goes this way for other socket (L-Yellow, N-Black, G-Green) Whereas for light switches, they are all using yellow color wire. Please suggest if you have any idea as this is the first time I encounter such problem. Share this post Link to post Share on other sites
Pelect 3 Report post Posted July 1, 2016 Can post some pictures? Share this post Link to post Share on other sites
Sumith 0 Report post Posted August 14, 2016 Well one way would probably be a continuity short circuit test to detect your wiring. Is it concealed? Share this post Link to post Share on other sites
skb 2 Report post Posted August 28, 2016 How many gang and way light switch is yours. 1 way switch should be easier to test, use a test pen to test for "live" wire and "no live" wire. The rest should be quite straight forward with some trial and error. Share this post Link to post Share on other sites
