tost
MCB trip
When I use my power drill (also borrowed from friend to make sure mine is not the cause) and run into tight spots, my RCCB and MCB (both the one with single push switch and the one with dual push switch) will trip, turning off all my electricity. So I bought a 10mA RCD plug http://www.horme.com.sg/product.aspx?id=2217 hoping no need to keep resetting the MCB. I also changed the RCCB but problem still there. But the tripping still happens. Is there any other thing I can do?
Did you use both the drills from the same wall socket?
I am not an expert but maybe there is a fault in your wall socket.
The other I can think of is the extension wire (if you are using).
This seems the more likely cause in my opinion
