kelvintzy 0 Report post Posted June 6, 2016 hi bros and sis! anyone has any idea how often we should polish our parquet floors and any maintenance tips for parquet flooring? TQ in advance! Share this post Link to post Share on other sites
evelow 0 Report post Posted December 15, 2016 Kelvin, polishing frequency is really dependent on how much traffic that space is getting. Some rooms see heavier usage so we do so once in 2-3 years. Especially those areas that are nearer to bathroom cos of moisture. You can try going to this link for some advice! Parquet floor polishing maintenance tips Share this post Link to post Share on other sites
bepgof 20 Report post Posted December 25, 2016 Watch out, the wood shrinks and twist when temperature/moisture varies.... Share this post Link to post Share on other sites
Glenn72 65 Report post Posted December 29, 2016 On 06/06/2016 at 10:40 PM, kelvintzy said: maintenance tips for parquet flooring? You can try something called HCL89 from http://hcl89.byethost10.com or http://hcl89.atwebpages.com for cleaning and maintaining your parquet flooring What it does is it cleans it and renews your parquet tiles so that it will always remain new Hope this helps you out 10 Share this post Link to post Share on other sites
spike 9 Report post Posted January 3, 2017 My 1 year old parquet floor is filled with scratches. I am not sure if it is the quality of the parquet used or just rough usage. Share this post Link to post Share on other sites
Arfan 64 Report post Posted June 30, 2017 On 26/12/2016 at 7:03 AM, bepgof said: Watch out, the wood shrinks and twist when temperature/moisture varies.... Never knew this as i always thought only those unvarnished woods will shrink 6 Share this post Link to post Share on other sites
fastlocalgaragedoor 0 Report post Posted July 12, 2017 If you avoid moisture and clean parquet floor with a suitable material .You will not face this problem again. Share this post Link to post Share on other sites
Lovalova 0 Report post Posted October 15, 2017 On 6/6/2016 at 10:40 PM, kelvintzy said: hi bros and sis! anyone has any idea how often we should polish our parquet floors and any maintenance tips for parquet flooring? TQ in advance! I maintain and clean mine by using this particular cleaner called bona. Sorry for the very late reply. Just joined this forum today =) Share this post Link to post Share on other sites
BenBernanke 117 Report post Posted March 26, 2019 On 7/12/2017 at 7:16 PM, fastlocalgaragedoor said: avoid moisture Problem is moisture will always be there and moisture is an issue that is very hard to avoid 1 Share this post Link to post Share on other sites
TedDibiase 216 Report post Posted June 28, 2023 On 7/1/2017 at 3:14 AM, Arfan said: thought only those unvarnished woods will shrink Alot of wood materials shrink because the varnish wears out after a while, so if you go for wood make sure its treated wood so the shrinkage is very minute Share this post Link to post Share on other sites
