elastic25
WATERPROOFING THIN SET TILE BONDING, TILE BONDING, NEW TO OLD CONCRETE BONDING AND SEALER
Cement added with  K 21 : SBR LATEX will have:
  • Strengthens cement
  • Improved bonding strength by 2 to 3 times to 30.57 kg/cm2
  • Especially good for bonding homogeneous tiles, granites and marble tiles, and to prevent staining
  • Increased flexural and compressive strength by 40% to 100%
  • Compressive strength to 570.00 Kg/cm2
  • Flexural strength to 127.41 kg/cm2 (ASTM C 39)
  • Quicken cement setting time
  • Reduced surface cracking and dusting, forming a very tight seal
  • Good for wall plaster, wet area and swimming pool waterproofing
  • 10 to 20 times more resistant to oil, salt water, chloride, acid and vapour penetration. A feature particularly important in steel reinforced concrete structure.
  • Improved plasticity and flow (ASTM C 124-71), easier to work with, reduces porosity
