fatpanda
Any recommendation for elevator company
Hi
I have an existing lift with lift shaft (around 1750mm x 1750mm) with lift pit depth (around 750mm) serving 3 stops.
Anyone has recommendation of elevator company that can replace my existing lift or make use of existing fixture to re-construct a new one (i.e. lower the costs of lift replacement)? I am open to both hydraulic or traction lift.
  On 8/23/2016 at 3:58 AM, mrenotalk said:
Hi All
For a new erection, can one get a home lift (covering 3 levels) for $70k?
Thanks
Do you mean just the cost of the lift, or does this budget include building the lift shaft? For just the lift, it is possible. I have approached the branded ones like Schindler Lifts and even they can do it for this budget. If you don't mind the Taiwanese/China brands, you should be able to purchase the home lift for even lesser.
  On 8/29/2016 at 6:35 AM, mrenotalk said:
wow...the regular maintenance cost is not cheap... $300+ per month?
$200+ for those that comes with the lift brand. Or you can get third party maintenance companies to do it for $100+. Hope this helps!
Like which lift brands? I think I called one of the guys you recommended and was indicated 300+.
Thanks
