Product Description :K25
After mixing with Portland grey Cement .
  • Bonding – excellent bonding property, will bond onto cement, sand, polyurethane, and bitumen
    surfaces. Therefore it can be coated over existing waterproofing membrane layer.
  • Flexibility – Cured coating is elastic, flexible, and very stretchable with excellent contour conforming ability.
  • Weathering – It is a chemically stable product, resists UV ageing, temperature changes, and remains impermeable to water.
  • Withstands wide temperature changes – does not blister or soften at higher temperature; remains  supple and flexible at lower temperature.
  • Chemical resistance – resistance to mild acid and alkaline solution.
  • Tough and resilient – suitable for various type of waterproofing needs.
  • Environmentally friendly – It does not contain organic solvent, does not pollute, flame resistance,safe to use.
Packing : 4 kg
