AirconCiti
AirconCiti - Your One Stop Aircon Solution
Hello,
Can you quote me for 4 room BTO.
Looking for System 4 inverter for my 3 rooms and 1 living room,  please quote me Mitsubishi Electric Starmex (2 & 5 ticks), living room may consider 12K and 18k  BTU.
Kindly include GST,
 -installation (2 times installation)
 -1/2" Armaflex class "0" insulation
 - G22 copper pipe
 -16mm drainage
 -additional cost for any length of pipe used for installation?
 -warranty (parts and installation)
Breakdown the cost if possible for comparison. Thanks you!
22 hours ago, huggermonster said:
Hi Eva,
I am not sure which system configuration to get. Will need recommendation. Will like to install aircon for my 3 bedroom and one living room. Living room abt 35sqm(so is 18kBTU enough?) For bedrooms looking at  2X 9k BTU and 1X 12K BTU. Please give me a quote based on various brands/models and the type of piping etc. Thanx.
Hi huggermonster,
Thanks for your enquiry.
I've just PM-ed you the quotation.
Please do not hesitate to contact me if you have further clarifications.
Have a nice day!
Eva
67558255 / 96758255
2 hours ago, Alvincheng said:
Hello,
Kindly include GST,
 - G22 copper pipe
 -16mm drainage
Hi Alvincheng,
Have a nice day!
Eva
67558255 / 96758255
Hi, can you please quote me for the following?
Mitsubishi Starmex Model: MXY-4A28VA / MSY-GE10VA X3 + MSY-GE24VA (2 ticks model)
Requirements:
- materials: G22 copper coil, 1/2" Armaflex class "O" insulation, 16mm PVC drain pipe with armaflex insulation, 3 core 40/70 Keystone control wire
- others: 2 trips installation, dismantling & disposing of existing system 3 air-cons
- work with my ID on the required works
Thanks.
Requirements:
Thanks.
Hi Bunnybluey,
Have a nice day!
Eva
67558255 / 96758255
Need 2 quotations - TYPE HDB and BTO
Looking for System 4 inverter  for my 3 rooms and 1 living room,  please quote me Mitsubishi Electric Starmex (2 & 5 ticks), living may consider 12K and 18k  BTU.
Kindly include GST,
-warranty (parts and installation), etc....
Breakdown the cost if possible for comparison. Thank you.
Jason
Hi Jacob,
Have a nice day!
Eva
67558255 / 96758255
Hi Eva,
Please quote for System 4 Mitsubishi Electric Starmex (2 and 5 ticks). 5 room BTO, Bedrooms 9k BTU, Living 18k BTU.
Kindly include GST,
 - G22 copper pipe
 -16mm drainage
Thanks
Desmond
59 minutes ago, desmtooh said:
Hi Eva,
Kindly include GST,
 - G22 copper pipe
 -16mm drainage
Thanks
Desmond
Hi Desmond,
Have a nice day!
Eva
67558255 / 96758255
Hello,
Can you quote me for 5 room BTO.
Looking for System 3 inverter for my 3 rooms,  please quote me Mitsubishi Electric Starmex (2 & 5 ticks).
Kindly include GST,
 -installation (1 time)
 - G22 copper pipe
 -16mm drainage
Breakdown the cost if possible for comparison. Thank you!
   0
11 hours ago, slickkon said:
Hello,
Kindly include GST,
 - G22 copper pipe
 -16mm drainage
   0
Hi slickkon,
Have a nice day!
Regards,
Eva
67558255 / 96758255
Hi ,
Please quote the following for 5 rm BTO which I like to air con 3 bed rooms, 1 study room, 1 living room.
MITSUBISHI SYS 3 - INVERTER (2 ticks)
MXY3A28VA
MSYGE10VA x 02
MSYGE24VA  x 01
MITSUBISHI SYS 2 - INVERTER (2 ticks)
MXY2E20VA
MSYGE10VA x 02
- installation
- 1/2" Armaflex class "0" insulation
- G22 copper pipe with PSB Tested
- 16mm diameter with ¼’ thinness insulation
- Cables – 4C40,4C70 with PSB Tested
- PVC Trunking – minimum 2mm thick
- additional cost for length of pipe used ?
- warranty (parts and installation)
Thanks
Hi there,
I will like to get quotation for myself and my friend's house below:
Quote 1 - Landed Property
Panasonic single split - CU-XS9RKZ (new model, 9000 BTU)
Quote 2 - HDB
Panasonic system 2 - CU-2XS18RKZ (new model, 2 x 9000 BTU)
Questions
For survey, is it available on weekend or after 6PM?
Is installation available on Saturday?
