yahoo
Placement Of The Stove
Hi I have a few questions regarding the placement of the stove. Due to space constraints, I can only put my stove in the following:
1. Stove facing washing machine which the washing machine will be put at the service yard.
2. Stove indirectly beside fridge where in between will be microwave owen, rice cooker.
The other 2 option is definitely out because its either 1, facing door or 2, beside window which is also indirectly beside the washing basin.
Please advice,
Thanks.
Hello yahoo
Again, as I can't see any pictures, what I can advise is that you take option 2.
how about my stove position? the left is facing west and right where the full-ht cabinet is facing east
Base on the drawing, it is alright. What is on the right side of the stove? Where are the windows?
hi sorry, how about this layout?
can advise if the stove and sink can be in one line or not?
now big big headache coz heard that sink and stove cannot be in a line
thank you so much
thank you so much
Hello
Now better. It seems to me quite alright.
I don't know from whom you've heard of that. Anyway, you can put up some small potted plants in between.
Also try to keep your yard door closed at all times
Edited by Mr Chong
in this case can open the window or not?
thought will open the window and door to yard when cooking
also, right next to the sink, in the yard is the washing machine. no problem right?
thank you so much. you have been such a great help :yamseng:
thank you so much. you have been such a great help :dancingqueen:
Its better that you indicate the stove position/s. Generally, it is preferred that it doesn't face doorway or windows.
WM is alright.
Welcome.
Understand that stove is not to be placed opposite the washing machine. How abt beside the washing machine. Will that be advisable?
VM is as good as a wash basin, isn't it?
hi mr chong
my kitchen is very small and the only place that i can place the fridge is directly opposite the stove which also has a built-in oven. is this ok?
i heard that stove should not be directly opp the fridge. is this correct?
thank you
Hi Mr Chong,
I have similar situation too. Due to the space constraint, my stove have to face my washing machine.
Any advice pls.
thanks.
Hello tientien and ah kiat
Actually, the whole situation need to study on a case by case basis. It may not be necessary that bad. Try to put up your floor plan so that I can make further comments.
At the moment, a very simple solution is avoid doing the 2 things together. If you cook don't wash and vice versa.
Hi Mr Chong,
Would like to know which layout is better in your opinion?
Plan A
or
Plan B
Thank!
:notti:
Hi Mr Chong,
Plan A
or
Plan B
Thank!
:yamseng:
Hello
Generally speaking, layout A gives better space management. But you still have to investigate your house FS
