onepoorboy
Got A Quote From A New Id Company, Reasonable?
Shoe Cabinet Full Height / 5ft in Laminate Finish - 850
TV Console 8ft - 1350
Full Height Casement Door Laminate Finish Wardrobe 6ft - 1200
Full Height Casement Door Laminate Finish Wardrobe 4ft - 850
Full Height Bookshelf with Glass & Wooden Door 4ft - 1000
Study Table with 1 row Drawer 5ft - 850
Suspended Cabinet top over Study Table 5ft - 450
Cabinet with Door under window recessed area 4ft - 420
Bookshelf Glass/Wood 1ft - 300
Kitchen Cabinet Top&Bottom inc. Solid Surface - 5700
Cabinet Base 50mm 20ft - 450
These are basically the prices I would like to compare. Are they reasonable?
Hi OPB,
Full Height Casement Door Laminate Finish Wardrobe 6ft - 1200-$200/PFR is normal
Full Height Casement Door Laminate Finish Wardrobe 4ft - 850- should be $200/PFR unless something different
Kitchen Cabinet Top&Bottom inc. Solid Surface - 5700- Depends on your overall length of cabinet and SS-$240/PFR for Kitchen cabinet is common and $80/PFR for SS is common.
Cabinet Base 50mm 20ft - 450- mine is incorporate into the packaging(Basically FREE)
Hope it helps.
4744
Hi onepoorboy,
I think what Daniel says is about there. Bit u cannot compare prices based on this alone because different ids marked up differently. U must look at the overall quote. Eg. He can give u cheap carpentry but tiling works is more expensive. So u must look at the overall.
Eg. Wardrobe 200-230 Tiles 100 - 130. cabinet 200-230. Roughly all items in the range them should be ok la.
