jwchu168
Feedback On Renovation Quote After 2 Rounds Of Negotation
Hello All,
Hoping to seek your advice if the latest quote is inline with market or have furthur room for improvement? My ID claims that this is the best best price they have already but I think best to consult the shifus here.
Thank you in advance.
Rgds
Colin
ITEM DESCRIPTION
- Project Documentation and administration $ 1,000.00
- Supply labour and material to protect and clean the affected apartment at level 1 and 2 $ 1,400.00
- Supply & install plaster ceiling board as proposed at following area;Living & Foyer (284 sq ft) $ 1,800.00
- Supply labour and material to paint 2 levels (Emulsiion + base sealant coat $ 2,600.00
- HACKING AND CONSTRUCTION WORKS; $ 6,000.00
a. Remove existing Balcony railing
c. Remove existing sliding door between Balcony and Living
d. Remove existing wall at Service yard
e. Remove existing wall at Kitchen
f. Remove all existing cabinet
g. Remove all existing sanitary wares
h. Remove all existing floor tiles in Kitchen
i. Remove all existing wall tiles and floor tiles in Common Bathroom
j. Remove existing roof in balcony
k. Remove existing wall tiles and floor tiles in Master Bathroom
l. Remove existing wall tiles and floor tiles in Common Bathroom
n. Remove all existing sanitary wares at Master and Common Bathroom
Construction works as per following;
- Supply labour and material to lay cement screed for affected flooring and wall as per following;
Kitchen $1,000.00
Helper room and Store (Incl. to construct new Hollow block wall) $3,000.00
-Common Bathroom (Incl. to construct new Hollow block wall) $2,400.00
To construct and lay HERF Flooring with wooden skirting as per following;
-Living, Foyer (530 sq ft)$ 3,600.00
-Balcony (214 sq ft) $1,400.00
-Helper room (73 sq ft) $500.00
-Store (73 sq ft) $500.00
- Supply labour and material to install kitchen kerb in selected material and finishing. $500.00
- Supply labour and material to lay waterproofing in Common bathroom and Kitchen. $400.00
- Supply and install partition wall at the following area;
- wall divider to Store and Helper room (L2000 mm)$500.00
- Supply and install Aluminium Composite Panel Roof at Balcony. $3,500.00
- Supply and install Enclosed Full height window casement in selected finishing. (L6400 mm) $ 3,500.00
Master Bathroom $ 3,000.00
Common Bathroom $ 3,000.00
Supply labour and material to lay waterproofing in Master Bathroom and Common Bathroom $400.00
Clearing debris after hacking $ 300.00
PLUMBING WORKS ($2,400)
- Supply labour & install as following; (Accessories by owner)
a. To run new copper water piping for 2x Common bathroom,1x Master bathroom and Kitchen
b. To install sanitary bowl, basin,and taps/mixers a 2 x common bathroom and 1 x master bathroom
c. To install all the accessories at 2x Common bathroom and 1x Master bathroom
CARPENTRY & FURNITURE
- Supply Top and Bottom cabinet in selected material and finishing. (L5950 mm) $6,300.00
- Supply & install Solid Surface Counter Top in selected finishing. (L6500 mm) $1,500.00
- Supply & install Vanity Storage with Solid Counter Top in selected finishing. (L800 mm) $800.00
Supply & install Vanity Storage with Solid Counter Top in selected finishing. (L1200 mm) $1,000.00
Supply & Vanity Storage with Solid Counter Top in selected finishing. (L800 mm) $800.00
M&E WORKS (note. All the light fittings purchases by owner)
- Supply & install necessary electical point on the affected area; $ 5,500.00
a. lighting point 49 nos.
b. power point 20 nos.
c. TV point 2 nos.
d. Data & Voice point 2 nos.
- Supply labour & material to Glass Shower Screen for 3 bathrooms $ 2,400.00
- Supply and install Tempered glass backsplash in kitchen. (L4700 mm) $ 1,300.00
Special Discount $ 3,300.00
Grand Total $ 59,000.00
Newbie too, but I saw something that raised my eyebrow
Market price for kitchen cabinet per foot run is about $110 with soft closing if you google around.
for your case
5950mm =19.54 feet
19.54 feet x 2 (if i did not interprete wrongly that top and bottom means multiple by 2)x 2 (if i did not interprete wrongly that top and bottom means multiple by 2)
=39.08 feet
taking $6300 / 39.08 = $161.2 per foot run
For this price, does it come with BLUM soft closing?
Edited by chalkboard
for your case
5950mm =19.54 feet
=39.08 feet
It does come with soft closing but not BLUM. For $110/ft run, is it contractor price or ID price range btw?
  • Like 1
Contractor price is $110 or less. You design they build. They can come down to ensure you gave the correct measurements or perhaps give you a simple design but colours you gotta pick yourself. For ID price, it can be lower than what you are quoted. Confirm plus chop.
